05 Civic: Is my tranny about to fail?
Old May 19, 2015
MajTom's Avatar
MajTom is an unknown quantity at this point
Exclamation 05 Civic: Is my tranny about to fail?
2005 Civic Hybrid, just a tad under 40K miles.
I've never had any problems with the Auto Transmission.
Today as I was cleaning around the battery tray, I looked closely at the tranny housing. What I saw was not good. Over the metal surface was fine webbing, like very tiny cracks. Check out the picture and tell me what you think. Look at the center, top, and upper right. The pic is focused above the tranny fluid cooling line. Should I be concerned with this? I don't see any webbing like this on the engine block.
Old May 19, 2015
Re: 05 Civic: Is my tranny about to fail?
Looks normal to me, nothing I would worry about.
2005 with under 40k? WOW!
Have you changed the CVT trans fluid yet?
Old May 24, 2015
honda200192's Avatar
honda200192 is an unknown quantity at this point
Im wondering if there is a top coating on your transmission that is just cracking. Or if its the actually transmission housing thats cracking. If its the actually transmission housing thats cracking.....thats not good.....the only thing i could think of would cause that Is maybe you or the owner before bottomed out the car and the transmission got hit. But if you bottomed it out you would of known so im taking it YOU didn't but maybe the owner before did.
Old May 25, 2015
Star1967's Avatar
Star1967 will become famous soon enough
Only way to really tell is if the put the ultraviolet dye in and cycle it through. If it shows up in the cracks the transmission housing is shot. other than that it just looks cosmetic. At 40K you shouldn't have any trouble unless you have gotten the vehicle from someone that thinks since it has 4 wheels it's a 4 wheel drive.
Old Jun 2, 2015
MajTom's Avatar
I asked my brother who's worked on some before; he said it's normal. Also checked some other Hondas...it seems like a pretty common occurrence. It's even on my folks' '02 Accord engine block, and they never had trouble with it.
I'm the 2nd owner, and the underside is scratch-free.
Yeah, I've changed the fluid before.
For a while there, this was causing me some concern.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
solarpunk70
Apr 12, 2016 11:43 AM
Bonobo
Oct 2, 2015 06:58 PM
260000milesgoal
Sep 25, 2015 07:41 PM
dantheman42
Sep 4, 2015 01:10 PM
