Car suddenly loses power please help
Old May 14, 2015
Shakzhussain's Avatar
Shakzhussain is an unknown quantity at this point
Hi basically I have a Honda Civic ep2 facelift 1.6 2003. Back in March I adjusted the throttle cable and after doing so suddenly my car would lose power by that I mean I would do my biting point as usual then realise my gas is not working for a few seconds like it would not respond but the car would not stall after a couple of seconds it was back to normal. So I unadjusted the throttle cable hoping it would fix it which it did for a few weeks but just the other day it happened again and I don't know what to do where to start this never used to happen before adjusting the throttle cable. I thinks it is fuel related and that fuel filter is clogged up. My engine light does not come up either so it doesn't seem electrical although my catalytic converted needs changing but that was since last year so I don't think it's that. Can somebody help me please thank you ☺️
Old May 14, 2015
Poopies's Avatar
Super Moderator
Re: Car suddenly loses power please help
Well...
You can get your OBDII scanned to make sure there are no hidden codes/ check your emission status
You can check your fuel filter
Clean your throttle body
What adjustment did you make to your throttle cable?
Old May 15, 2015
I have done that no hidden codes my engine lights goes off for cat converter every time I have got on the highway doing more then 50mph then I just reset the light. The fuel filter is hard to reach so I will just get it changed soon by Honda and I have cleaned the throttle body and spark plugs changed last week. Thank you for your reply much appreciated
Old May 15, 2015
Bare in mind this problem is intermittent happens once everyb2 weeks or so, so it is hard to pin point for me thanks
Old May 15, 2015
Star1967's Avatar
Star1967 will become famous soon enough
Where do you get your gas and is there signs of water in your fuel tank? Water tends to dampen the spark making the car bog down. over the years I ran into similar situations when I was forced to use inferior gas or fill up during or after a storm. Try a gas dryer like Heet or a cleaner like Lucas top end lubricant or STP injector cleaner every other tank full. I need to get some for my 2001 Civic.
Old May 15, 2015
How do I check for water in fuel tank? And I am considering fuel system cleaners but heard bad things about them so I'm stuck
Old May 15, 2015
Poopies's Avatar
Super Moderator
I always keep a stock of LubeControl's FP Plus on hand, but you can't go wrong with buying some Techron additive. Also using top-tier gas as much as possible helps too.
http://www.toptiergas.com/retailers.html
Old May 16, 2015
I apologise I don't understand what you mean by FP as I'm from the UK London so we may call them something else here mind if I ask what they are? Thanks and I do use BP Fuel and fuel from Shell
Old May 16, 2015
Poopies's Avatar
Super Moderator
It's a fuel additive that I use with EVERY tank.
http://www.lubecontrol.com/
That's definitely top tier. Nice!
Old May 17, 2015
Star1967's Avatar
Take a sample from the fuel line that leads to the injectors. If you see separation or foam on top of the gas you have water I've seen a few cars with a see through inline fuel filters in the engine bay.
MN-02-CivicEx
28
May 2, 2015 09:11 PM
Blaster30
Apr 22, 2015 12:21 PM
McD
Apr 16, 2015 10:46 AM
SSMatey
Apr 13, 2015 06:09 PM
deus-ex
Apr 13, 2015 12:29 PM
