Putting Engine
Putting Engine
my 2001 Honda Civic check engine light is on but no scanner can read it? We've tried 5 very good ones. My tachometer isn't working my car sounds like it's misfiring we just did a full tune up and the car like puts you can't go over 42 or it will stop working. I was told I may need a cam sensor? Please help I can't keep putting money in the car?
Re: Putting Engine
Linky click: http://www.brakeandfrontend.com/tech...ernator-bolts/
Re: Putting Engine
I checked that fuse and it isn't broken so not that easy of a fix i guess. When i go over 42mph the car starts to putt and feels like its going to shut off and the tacometer doesnt work I'm desperate for help!
Re: Putting Engine
The inability to read codes and dead tachometer suggest what Ezone posted. I'd suggest you take it professional Honda specialists (dealer).
You can't just throw parts at the problem. Likely at fault is the PCM. But if you have loose alternator bolts you will keep frying PCMs until the bolts are correctly tightened.
Let us know as you progress in solving it.
Re: Putting Engine
Sometimes a problem just isn't simple and cheap LOL
