engine mount questions
Old Apr 1, 2015
bsmiley's Avatar
bsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nice
01 LX 5MT
i'm planning on replacing my trans/engine mount & the front engine mount in the next few days.
How can I check if the rear mount needs replacing?
Any tips for getting them installed properly? Just support the engine & swap the mount?
TIA!
Old Apr 1, 2015
Re: engine mount questions
^This.
Depending on what you are going to do, you may need to be able to move the drivetrain up and down and around a little to get bolt holes lined up so you probably want to use a floor jack and blocks of wood, prybars, tapered punch for lining up holes....
OEM mounts FTW!
If you got aftermarket, don't complain about vibration LOL
HTH
Old Apr 1, 2015
Pretty much hit the nail on the head in your post. Kudos to you.
I will say this much though. I have 180k on my 02, I've removed my engine/tranny, I've replaced (rather, DIY repaired using Devcon Flexane 80) my front and transmission motor mounts. My rear mount, aside from being a bit dirty over the years, showed no signs of cracking or excess fatigues, like my transmission and front motor mounts displayed. Take that for what it's worth.
Old Apr 2, 2015
thesushiboy's Avatar
200,000 and counting
thesushiboy is a jewel in the roughthesushiboy is a jewel in the roughthesushiboy is a jewel in the roughthesushiboy is a jewel in the rough
Originally Posted by bsmiley
01 LX 5MT
TIA!
I've got an '01 with 198,000 and replaced the mounts. There is a specific sequence that seems to work: http://honda-tech.com/tech-misc-15/m...olved-2779057/
But if I could offer one piece of advice, go OEM. I tried to save money and bought an off brand from Amazon. My car shook like a Tiger Tank. I rode it out for a year, thinking the mount would settle...nope. After I changed out my timing belt, I bought an OEM mount and my car is like butter.
Old Apr 2, 2015
bsmiley's Avatar
Thanks for the replies. I replaced the front & trans mounts. A little tricky to get to the bottom bolts on the trans mount, but not bad.
Seems to have made a big difference. I was a little concerned because the mounts I removed seemed okay and about as stiff as the new ones. But I don't feel things moving under the hood anymore. At least not like before.
I think the rear mount needs to be replaced too. that looks really tough to get to... another project.
mikemc422
Aug 9, 2018 05:41 PM
zack22490
Apr 29, 2015 03:17 PM
bsmiley
Apr 27, 2015 01:27 PM
streetglower123
Apr 12, 2015 10:56 AM
WhosYoDadday85
Nov 13, 2001 09:38 PM
