Evacuated AC but wont take freon
Old Jan 5, 2015
alex_nyc's Avatar
alex_nyc is an unknown quantity at this point
2003 1.7 civic ex sadan
So I cant get the Freon into the system after an ac evacuation. The system was good before I replaced the ac hose.
do I need to do something to get the clutch to turn on??
thanks
Old Jan 5, 2015
johndeerebones's Avatar
johndeerebones is a jewel in the roughjohndeerebones is a jewel in the roughjohndeerebones is a jewel in the rough
Re: Evacuated AC but wont take freon
No the small amount of refrigerant pressure in the can which I assume your using is more than enough to trip any pressure switch on any system. Never open the high pressure side to the can while the engine is running and barely open the low side to charge. If you open the valve much, it will freeze the can and Freon flow will be very slow from it. You can also put the can into a bucket of hot water or on the manifold to warm it. If it is cold where you are working good luck... A/C work and cold temperatures are next to impossible to get right out of a can. A 30lb cylinder and a scale or a recovery machine is about the only two ways to do it with any accuracy in the winter...
Old Jan 5, 2015
alex_nyc's Avatar
is there a way to trip the compressor on?
Old Jan 5, 2015
RIPSAW's Avatar
RIPSAW has a spectacular aura aboutRIPSAW has a spectacular aura about
Yes, just jump the two wires together on the plug that is in the pressure line. All it is a switch held on by the pressure in the line. it's there to prevent the compressor from running with a low charge (with no charge, the compressor would pump the oil out and soon lock up) Lot of fancy systems (with temperature control and a evaporator valve..not just a jet as most have) once called for this to be jumped to charge if you are using small cans. I charged a Mercedes and it would not take gas till I jumped it to get compressor to run. However, not an expert but that was in the manual to do and I tried my normal way that had worked with my Toyota.
Old Jan 5, 2015
alex_nyc's Avatar
i already tried that! I dont think honda works that way!
wondering if there is way to command the Ecm to turn on the compressor??
Old Jan 5, 2015
How much pressure do you have in the system now?
Old Jan 5, 2015
alex_nyc's Avatar
the high side was 40lbs
Old Jan 5, 2015
That's enough static pressure to trip the safety pressure switch by itself. (meaning you shouldn't need to jumper it)
Do the fans come on when you turn the AC on?
When was the last time you knew the AC system worked?
And how cold is it there? Is the car inside and warm?
Old Jan 5, 2015
alex_nyc's Avatar
no fans. no click from the clutch
ac worked fine a few weeks ago before the hose broke. it was good n cold. car is outside in cold 30's
i shorted each of the 2 switches. 1 at a time then both at same time. no clutch sound was heard & no fan.
Old Jan 5, 2015
shorted which 2 switches?
30 seems awful cold to be messing with the AC system LOL, may be too cold
system must be over 28 psi to run, that's the pressure switch on the drier
what other switch? thermal protector on the compressor?
Old Jan 5, 2015
alex_nyc's Avatar
i was first messing with the switch on the high side near the firewall(looked like the GM pressure switch). that didnt work so I tried the switch on the drier.
Old Jan 5, 2015
Got a pic of that?
That might have been the power steering pressure switch. Follow the hose.
Old Jan 6, 2015
RIPSAW's Avatar
It's on the drier on the part fish. By any chance, did someone put an extra one on the line that is not OEM?
Old Jan 6, 2015
It's on the drier
Ayup
Old Jan 17, 2015
alex_nyc's Avatar
Ayup
hey im back! Thanks for the replys!!
It was a lil warmer so I was able to add Freon today.
The AC works fine now. Hopefully it will help defrost the windows now.
(ill get a pic of the low side switch soon.)
thanks again!
Deebo12
Air Conditioning
Sep 26, 2015 11:08 PM
BJB
Sep 14, 2015 11:16 PM
cukaracha
30
Jul 26, 2015 12:01 PM
cukaracha
Jul 23, 2015 08:50 AM
Jul 14, 2015 03:39 PM
