Stuck Outer Tie Rod!!!!!
Old Oct 18, 2014
mrohitredd's Avatar
mrohitredd is an unknown quantity at this point
Neither does the nut nor the old tie rid unscrews... Tried penetrating fluid & (about to) propane heat torch... Any other suggestions?
Thx in advance
Old Oct 18, 2014
Re: Stuck Outer Tie Rod!!!!!
Fire can be your friend.
Gotta be careful with it though, a little heat can go a long way.
Old Oct 18, 2014
mrohitredd's Avatar
no luck yet... tried propane gun...
Old Oct 18, 2014
You turning the correct direction? Tie rod ends and hardware can sometimes get confusing.
I use oxy-acetylene for heat, not propane. I get at least part of the nut red, that is usually enough to get it freed up.
MAPP gas might get hot enough?
Yeah those suck when they get stuck. Hell of a bad place, especially when trying to do a wheel alignment.
Old Oct 18, 2014
mrohitredd's Avatar
somehow, i was expecting the first & most replies from u #eZone.. I'm right again
AT LAST !!!
Got it through...
Propane Gun helped... Managed to get a flame on top of it
Used an adjustable wrench to loosen the nut...
Both sides are out now...
Now i have a new Question...
I bought these - http://shop.advanceautoparts.com/p/m...581/20515912-P
It doesn't have a (screw) hole on top to fill grease... it has a (very) thin hole at the other end though... As far as i know, i have to fill grease before i put them... How do i go with these now ?
Help appreciated... Thanks
Old Oct 18, 2014
I don't see the name MOOG on here. Counterfeit?
The description says it's greaseable, yet no place for a zerk to thread in. Counterfeit?
True MOOG parts should say MOOG right on them IIRC.
Made in Japan?
Reboxed OEM?
Move the rubber boot to the side, see if it's already greased.
Old Oct 18, 2014
mrohitredd's Avatar
it looks almost empty...
Look at the tiny hole on top... does that mean something ?
Old Oct 18, 2014
The boot doesn't need to be full, but the body of the joint should be.
Take it back, throw it on the counter, say WTF?
Go with OEM?
Install these anyway, see how long they last? (Load with chassis grease first and work it in)
Old Oct 18, 2014
mrohitredd's Avatar
also... one strange thing i noticed... the original look similar too...but one small difference is that they don't that "tiny hole" either... Wonder how they even filled grease into them... :-/
Old Oct 18, 2014
Hmmm. Not sure what to think here.
Checked the MOOG (Federal-Mogul) site: http://www.fme-cat.com/overlays/part-detail.aspx?brand=MC&PartNumber=ES3581&pt=Tie%20Ro d%20End&lu=2003%20HONDA%20CIVIC&vin=
Old Oct 18, 2014
If the 'made in Japan' unit has a nylon impregnated bushing (same as OEM) instead of the powdered steel of the MOOG problem solver unit, I think I'd rather use it.
Old Oct 18, 2014
mrohitredd's Avatar
so u mean, not filling any Grease at all ?
Old Oct 18, 2014
OE is lubed as it is built, and then completely sealed.
Old Oct 18, 2014
I'd still squirt some chassis grease into it and move the stud around to work the grease in.
Old Oct 18, 2014
mrohitredd's Avatar
ok... will try that in the morning & update here...
been under the car all day & too drunk to get under now
Old Oct 19, 2014
mrohitredd's Avatar
Changed them to a drive works tie rods & finished off the work
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
rovafa2002
Sep 28, 2015 06:57 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
Joecrowe
Sep 24, 2015 09:12 AM
