Radio and door open light not working
Old Aug 17, 2014
t.saia2394's Avatar
t.saia2394 is an unknown quantity at this point
So I have just finished doing a cluster swap for my 2004 civic VP. I swapped to a 2003-2005 Lx coupe's cluster. The cluster and everything else in the car works properly...except my radio and the dome light when I open the door WITHOUT the keys in the ignition. When the keys are in, the lights will work with doors, but the radio still will not turn on at all. The dome light also does not come on when I remove the keys from the ignition like it should. Any help would be great!
Old Aug 17, 2014
Re: Radio and door open light not working
I'd think first thing would be to plug the original cluster back in and see if the issues are back to normal.
Old Aug 18, 2014
CraigW's Avatar
Check fuse named "backup"
Old Aug 18, 2014
^Yeah that.
I must have misread the description last night.
Old Aug 18, 2014
CraigW's Avatar
Likely just another one (er, two) and done.
May return, may not.
I swapped in a LE cluster into my 00 CE Corolla. Moved my speedo and odo into the LE cluster 100% plug and pray...... and then had outside temp display (by adding the thermistor) When I sold it, I took all back out and sold my LE cluster and thermistor to boot.
Old Aug 18, 2014
t.saia2394's Avatar
It worked!! It was the Back Up fuse lol. I checked all of the other relevant fuses last night but couldn't find anything. Thanks for the help guys! This is why I became a member lol
Old Aug 19, 2014
CraigW's Avatar
Good news, happens a lot when messing around with electrical items.
roverben
Jan 21, 2019 05:16 PM
MamaBear2015
May 3, 2015 02:17 PM
ORskier
May 3, 2015 12:54 PM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
TopFuel
Exterior
Nov 13, 2001 07:05 PM
