P0717 Tran problem
Old Aug 7, 2014
mcnug's Avatar
mcnug is an unknown quantity at this point
P0717 Tran problem
Im having a issue with my 04 civic.I am getting code P0717(speed sensor short to ground) so i changed my speed sensor with a used one and it worked good for two days then i got a code p0717(speed sensor no communication).i just put the old one back in to see what code I get so i will scan it tomorrow.it shifts fine but I get that code and the D light flashes. Anyone have any idea what the problem could beÉ
Old Aug 7, 2014
Re: P0717 Tran problem
Why 2 different code definitions for the same code?
Which one are you trusting?
Which speed sensor did you change? There's like at least 2 of them.
P0717 is for the input (main) shaft speed sensor circuit no signal. It's an electrical issue, it should not be a mechanical problem so that's a good thing. Broken/chewed wires? Worn female terminals in the plug?
Old Aug 8, 2014
mcnug's Avatar
i was wondering the same thing about why the two definitions were different. I think its where I am using the genesis scan tool and i can only read the trans code when I go into global
Theres no chewed wires that i could see.i tried to se if any was broken and couldn't find any. I have the old turbine speed sensor back in now and the only code i get is p0700.(which wasent there before with the original sensor and with the used one).
Also i checked the datastream and when im in park on the scan tool it says park, when in Reverse it says invalid when im in neutral it says im in park when i put it in drive it says in 1st the a second later it says im in neutral says im in neutral for D3 and says im in reverse for 2nd
I am a mechanic but this has me stumped.
Any help is greatly appreciated
Old Aug 8, 2014
I figured there were 2 different scanners involved, or something like that.
Speed sensor on the passengers end of the trans or on the front of the trans, or the one on the differential?
You got a P0700 NOW? Where the heck was this code before?
P0700 has no real definition....
In the dual-processor PCM, one processor is for the engine functions and the other processor is for the transmission functions. The factory scanner reads them separately even though they are in the same control unit, but some aftermarket scanners can read them at the same time..
Picture this: Car comes in with a CEL complaint. Plug in the scanner and check codes.
If the factory scanner is used I pick "engine" first, because the check engine light on is the complaint. I would find a P0700 which is a generic trans code, it only indicates there is a transmission problem and I must then back out of the "engine" section and go to the trans section to scan the trans processor to retrieve trans related info.
Clear code command erases codes from both sections of the PCM in most cases (I can't think of any that don't)
SO if you find a P0700, I suspect there is a trans related fault code hiding in there somewhere and you haven't found it yet.
Or it's your scanner having a glitch.
Try some different scanners, this sounds like yours isn't reading the datastream correctly.
Old Aug 8, 2014
mcnug's Avatar
The way its reading it almost makes me think neutral safety switch is bad.
Dont these cars have a TCM ?Im new to the 7th gens and auto(the wife cant drive a stick yet)
i know of two locations for the speed sensors the one on top(turbine) and the one on thee pass side.I know there's shift solenoids on the front
Old Aug 8, 2014
I wouldn't think that.
You had a speed sensor code MAYBE IF the scanner is accurate on that part. (I have been mislead by aftermarket scanner conflicts before, it really sucks).
Nope. PCM.
Oh yeah on the dual processor PCM comment, that style isn't used on all the cars but the factory scanner still treats them all the same when it comes to reading codes and data.
You are missing one....
The trans should have 3 speed sensors. Mainshaft, countershaft, and output (VSS).
I think the one you haven't found yet will be the problem LOL (IF the scanner wasn't lying about the code number)
Look again at the front of the trans facing the radiator.
Find #13
HTH
Old Aug 8, 2014
mcnug's Avatar
im guessing that would be #30 in the pic.lol. thanks a lot man i will try replacing the other two sensors and see what happens
Old Aug 8, 2014
#30 is just a bolt.
#13 is the mainshaft (or input shaft) speed sensor, that's the ONLY sensor related to the P0717 code.
Old Aug 9, 2014
mcnug's Avatar
#30 is just a bolt.
lol wasent really paying attention. thanks man i will give that a try
Old Aug 9, 2014
mcnug's Avatar
went out today to check if there were any broken wires and there were nose so i unplugged it and the plug was good. plugged it back in and it worked ever since
Joshh
Jun 7, 2015 03:24 PM
oneheadlight
Apr 29, 2015 11:30 PM
davidpaustin
Apr 29, 2015 02:23 PM
insan
Transmission
Jan 7, 2002 04:04 PM
Russps
Nov 8, 2001 02:00 AM
