P1457
Old Jul 18, 2014
mikey1's Avatar
P1457
where to start with P1457?
no visable cracks in any hoses
Old Jul 18, 2014
Re: P1457
Evap leak in the canister system.
3 solenoids involved. Purge (on engine), canister vent shut, and bypass.
Do they all click? (manually apply power and ground to activate each one)
You're up north in Canuckistan, got rust?
The common stuff I see:
Solenoid for canister vent shut is stuck open (no click) or doesn't seal when closed,
Purge solenoid restricted, causing pulldown time to be excessive
And rust. Here's a pic of a CVS that is rusted bad enough to leak out the seams
I think these were done with about 1 PSI on the canister system and soapy water sprayed all over it.
There's also a bulletin for 01-02 setting this code in cold weather and another with troubleshooting hints, but the above list is what I regularly see.
HTH
Old Jul 18, 2014
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
Re: P1457
What drawing and/or where are those parts located on majestics site?
Old Jul 18, 2014
Re: P1457
I picked 03 LX here
Purge solenoid is #8
http://www.hondaautomotiveparts.com/...=THROTTLE+BODY
CVS is attached to the end of the canister, and its screws are often seized and can't be removed, the embedded nuts just spin in the plastic canister.
CVS is #11,
Bypass solenoid is #15
http://www.hondaautomotiveparts.com/...L+PIPE+%281%29
Need more?
http://www.justanswer.com/honda/841m...place-pcm.html (Not sure what car this is about, but procedures appear similar.)
Factory scanner is immensely helpful in diagnosing these. Really sucks to try to manually do things even if one already knows how it's supposed to all work, and it sucks even worse when the problem isn't a common one..
Old Jul 19, 2014
mikey1's Avatar
Re: P1457
i think this was the problem,
i removed it from the canister (with great difficulty, was rusted just like that pic), i plugged one end and blew into the other end, i could hear air escaping through the seams,
so i replaced it, i have driven the car 3-4 times and no CEL light yet,
im going on a 200 mile round trip today, so that will be a good test, i should know by tomorrow, Lol
thanks!
Old Jul 20, 2014
mikey1's Avatar
Re: P1457
200 mile round trip complete,
i also drove it this morning once and still no CEL,
lookin good!
Old Jul 20, 2014
Re: P1457
Uan
Aug 23, 2015 03:03 AM
2005seTO
Aug 18, 2015 12:45 PM
greeni70
Jan 11, 2013 12:12 PM
cobra888
Oct 12, 2012 08:16 PM
wade623
Feb 15, 2012 03:04 AM
