immobilizer light not coming on
Re: immobilizer light not coming on
Do you have a real wiring diagram for this immobi system/circuit?
It sounds like there is a wire open circuit between the relay and terminal #6 (yel/blk wire) on the immobi connector on the column. That wire runs through those harness connectors I mentioned earlier.
omw back to my apt and i got immobilizers and no i dont have wiring..
So I got the immobilizer receiver from JY, they sold me that piece for 5 bucks because there was no price set, anyhow Install it and the green key light came on so my immobilizer in my car is done, by looks of it so my option are get reprogrammed by honda the one i got from JY or get bypass or am I still missing something ?
Yay. Now it needs to be programmed to recognize your keys and to tell the PCM it's ok to let the engine run.
Dealer, well equipped locksmith, or an independent or Honda specialty shop that has immobilizer access on their scanner. Call around and ask?
In my town, the dealer is the only place that has the equipment to program it.
When I needed to make new keys the dealer wanted $130 a key and the locksmith I went to could only clone keys. I ended up getting a programmer off ebay and then resold it. Worked fine and ended up being a lot cheaper. Search "sbb programmer". Looks like about $100 shipped from the US.
Not my video but this is pretty much the process:
https://www.youtube.com/watch?v=iHkjXekiGBs
so have this locksmith coming over and is going charge me 80 i explain to him the situation and he like"if bad conputer im still going charge u 80" dude if the ecm was bad other immobilizer wouldn't work either.
im happy to report the car is working again once he programmed the immo. so thank you those help me and especially ezone ur the man bro and thanks graig for wiring info and help.
V33.02 Universal SBB Programmer Immobilizer Multi Brand Car
Can you tell me the brand and model you ordered? Thanks.
CarStuff
Dec 6, 2020 12:52 PM
Flipg123
May 8, 2015 01:15 PM
dooner24
Apr 14, 2015 07:51 PM
