05 pushing coolant through overflow
Old May 25, 2014
89eliminator's Avatar
89eliminator is an unknown quantity at this point
so to start, i have been doing a lot of searching/reading.
i have a stock 05 1.7 with 124k. just recently, it started to push coolant through the overflow cap. i went to Napa and got a combustion leak tester. the kit says that if the fluid turns yellow, then its the head gasket. i have done three separate test and they all yield the same result (fluid turns a greenish color with just a hint of yellow. coolant is well below the recommended 2" below cap). the car runs perfectly fine, same mpg, same power. my old geo blew the head gasket and you could tell. from the reading i have done, it could be the water pump or head gasket. i was thinking water pump, but after reading threads on here its making me lean towards head gasket. i can go about 150-200 miles before i have to add coolant. i have not let it overheat yet.
any input is appreciated
Old May 25, 2014
Re: 05 pushing coolant through overflow
3/4 of these blown head gaskets will pass that test with flying colors.
You need a head gasket job.
https://www.civicforums.com/forums/3...reference.html
Search here and you will find about 3000 threads about them.
Old May 25, 2014
wouldnt i be seeing water in the oil if it was a head gasket?
Old May 25, 2014
Nope. None.
There's at least a dozen different ways a head gasket can fail.
All this does is seep combustion pressure into the cooling system.
Very slowly at first.
It would have to be a horribly overheated and warped head situation to have water in the oil occur on this engine.
Old May 27, 2014
if you bother to read the link provided, you would not need to ask that
Originally Posted by ezone
Mannimarco
Sep 7, 2015 10:01 PM
thaler4cuse
Sep 7, 2015 08:25 PM
johnsoda
Sep 6, 2015 04:00 AM
beantech
Sep 6, 2015 01:46 AM
Kyles24
Jul 16, 2015 10:14 PM
