Power Steering and Rear Cam Plug
Old May 13, 2014
2002-Civic-DX's Avatar
2002-Civic-DX is an unknown quantity at this point
Hey guys i'm new to the civic forums and i am seeking some advice and help on my civic. I took my 02 civic to a honda mechanic and he had replaced both strut assemblies in the front and did an oil change. He then told me that i had a small oil leak coming from the rear cam plug. He said that it would need to be resealed. So does that mean i would have to buy a new seal? If i do have to get a new seal, would i have to buy an o-ring or does that come with the new seal?
Old May 13, 2014
Hey guys i have a 2002 civic dx and there is a leak in the power steering hose so i will be replacing that, does anyone know how the long the job will take?
And i need to reseal my rear cam plug, if i bought a new seal would i also need to buy an o-ring separate? Thanks for the input!
Old May 13, 2014
Re: Civic Maintenance
Welcome to the forum!
You would buy the cam plug from a dealer, it comes with the needed seal as a one-piece unit.
About $9.
Pop the old one out, snap the new one in. Easy DIY.
Plug is item #6 here
Link to dealer in R.I., discount mail order:
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=CIVIC&catcgry 2=2002&catcgry3=4DR+DX&catcgry4=KA4AT&catcgry5=CYL INDER+HEAD+%28SOHC%29
Old May 13, 2014
Re: Power Steering and Rear Cam Plug
Moved posts to appropriate area and consolidated......
Which one?
There is more than one hose, and we can't assess your tooling, equipment, or abilities.
If you are talking about the high pressure hose, the factory thinks it should only take a pro about 20 minutes LOL
Old May 14, 2014
Which one?
Yeah sorry i don't know where to post threads.
It is the pressure hose by the way.
Old May 14, 2014
About $9.
I was looking on partsgeek.com and i was thinking that maybe it would still work if i bought the cam plug seal separate rather than buying a whole new seal. But idk, what do you think about that?
Old May 14, 2014
The correct part is LESS THAN $10 at any decent dealer, and you want to try to cheap out for less than that?
Good luck.
Old May 20, 2014
Good luck.
Hey ezone, is the cylinder head plug in the picture the same as the rear cam plug?
Old May 20, 2014
In my mind, yes.
Verbage can always be different between different people.
Point at what you want in the picture to get it right LOL.
The cap is to "cork" the hole where a distributor would go if it had one, and it can also the same as a camshaft bore (from the machining process) plug.
HTH
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
RIPSAW
Nov 6, 2015 04:36 AM
moorebl
Aug 29, 2015 08:39 PM
bsmiley
Apr 27, 2015 01:27 PM
Blaster30
Apr 22, 2015 12:21 PM
