Coolant Temp Higher at Idle
Old May 7, 2014
Deltab00ster's Avatar
Deltab00ster is an unknown quantity at this point
Hello All,
I've been using the Torque Android app to monitor my coolant temp and I e noticed that when driving (mainly at steady speed on the highway) my cooltant temp stays from 178°-185° F but during stop and go and idle it climbs to 195°-208°F. Is this normal? Or could my fan temp switch be failing?
Old May 7, 2014
mikey1's Avatar
Re: Coolant Temp Higher at Idle
i would say its normal, that is assuming the temp guage in your car stays in its "normal" spot and does not rise
Old May 7, 2014
kinakoes2's Avatar
*watches temp gauge like a hawkboss* :D
kinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of light
Agree, is normal. When the car is in motion airflow moves away more heat than when idling at a light.
If you think 208 degF is hot... the Honda motorcycles were even worse. In Phoenix my VFR800FI hit 215 regularly, by design, as did the old 929 and 954RRs... it was due to stock fuel mapping for emissions.
You may want to check your coolant level in the rad and if necessary, burp the system. Less coolant in the system means less fluid to absorb and transfer heat.
Old May 7, 2014
Yeah I just burped it yesterday but it still goes up to around 200° F. I'm just a little paranoid because I've had my HG go about 4 months ago and I want to do everything I can to prevent it from happening again so I want it to run cool. The fans come on but don't seem to kick in until about 205° F. Is that when they are supposed to come on?
Old May 8, 2014
kinakoes2's Avatar
That sounds fine... cool even. My SV650S motorcycle hit exactly those numbers and a little higher at idle (~205). And I had Water Wetter and a properly-burped system. Water Wetter and other surface-tension-collapsing coolant products will help bring temps down a bit, ~6 - 8 degF with a 50/50 mix for WW.
Using my Torque app today it showed at cruising I was hitting ~190 degF (driving in town)... didn't get a chance to catch idle temps at a light but I'm pretty sure they're in that ballpark, as the gauge stays rock solid. I also need to drop the coolant as it's old, so it bodes well for your observed temps.
Old May 8, 2014
Great thanks! The temp neddle on the gauge cluster stays just below the mid point all the time whether its at 180°F or 208°F so that's good. I'll be checking the coolant today again to see if there is any more air in there. I really hope there is not because that's what would happen when my HG went out originally.
Old May 8, 2014
mikey1's Avatar
then its fine....dont worry about it
lilrob1213
37
Jun 29, 2015 06:45 PM
zaboomafoozarg
May 30, 2015 09:21 AM
Allecr3
May 22, 2015 01:24 PM
F1wanabe
Apr 27, 2015 11:06 PM
Blaster30
Apr 22, 2015 12:21 PM
