2002 non-vtec engine in 2005
Old Apr 30, 2014
swali99's Avatar
swali99 is an unknown quantity at this point
Exclamation 2002 non-vtec engine in 2005
I replaced engine in a 2005 Civic; the new engine is from 2002 Civic and it does not come with EGR.
The car cannot pass emission test because of the engine light due to non-existence of EGR.
Any solution?
Thanks!!!
Old Apr 30, 2014
Poopies's Avatar
Super Moderator
Re: 2002 non-vtec engine in 2005
I also don't think it's legal to swap to an older year engine...
Old Apr 30, 2014
Is there a simple block off plate where the EGR valve would go?
Was the PCM swapped to go along with the wrong engine?
Old Apr 30, 2014
Poopies,
if the engine codes are the same, should not be an issue. they will not be able to prove without receipts, nor noticed
however, if someone tries to install a D16Y8 from a 6th gen on a 7th gen, that could be found just by looking at the engine code stamped in the engine block.
the engines were pretty much the same on the 7th gen, so no issues should appear or be noticed at a quick inspection - they should perform the same pending mileage
CarStuff
Dec 6, 2020 12:52 PM
izdman
May 19, 2015 03:43 PM
davidarenberg
May 16, 2015 08:45 AM
Grey
16
Jan 27, 2002 11:34 PM
AznSaint
Jan 8, 2002 12:58 AM
