Noise coming from the belt side under hood...
Old Apr 14, 2014
ATMJDM01's Avatar
Respect All, Fear No One
ATMJDM01 is an unknown quantity at this point
Question Noise coming from the belt side under hood...
I'm thinking it may be a bad pulley or bearing. Would like to know some opinions. The noise is HEAVY about the 36 sec mark and on. It's that constant hissing or screeching sound.
Old Apr 14, 2014
Re: Noise coming from the belt side under hood...
Man, my cat got all interested in the noise about :40 LOL
Does the noise change when the AC is turned on and off?
Have you tried using a stethoscope to locate the source of the noise?
Have you removed the belts to see if that eliminates the noise?
Old Apr 14, 2014
ATMJDM01's Avatar
LMAO @ cat comment.
Haven't done anything yet, my mechanic is going to help me soon to try and find a solution. Last time it did it he took a screwdriver and put his ear to it and tried to locate the noise but nothing.
It kinda is the same with the AC being off and on. It's just a little louder with the air off because you hear it more. Some people believe it's a pulley or the bearing in the tensioner. I've had the tensioner replaced twice so I don't think it's that one though.
Old Apr 14, 2014
mikey1's Avatar
remove power steering belt and run engine
noise gone?.....power steering pulley is fried
if not, remove alternator belt and run engine
noise gone?.....alternator pulley or A/C pulley is fried
if none of that removes the noise, then your problem is most likely in the timing belt area, or camshaft/valve train area
civicns
May 8, 2015 09:49 PM
Tarbris
Electrical
May 3, 2015 09:51 PM
Sparty
Nov 15, 2001 04:55 PM
eX2ooo
Oct 5, 2001 12:19 AM
ernhole1
Aug 2, 2001 11:12 PM
