DIY: Draining your fuel tank
Old Apr 13, 2014
Fudman's Avatar
Fudman is an unknown quantity at this point
So my daughter put diesel fuel into the Civic. Don't ask how. The Civic has the anti-siphon screen and there is no easy way to drain the fuel tank. Fortunately, I found this post: http://www.justanswer.com/honda/3p2z...002-civic.html
I followed it and it worked! You need to remove the box over the intake (undo vent hose, disconnect electrical plug, (3) 10 mm screws) to access the fuel line. It unclips easily by squeezing the locking pins. I then removed the rear seat bottom, opened the fuel pump cover (4-screws) and followed the instructions for jumping the fuel pump. I used a deep cycle fishing battery, some wire and alligator clips and it took about 45 minutes to drain 12+ gallons. I reassembled everything, added some gas and the car fired up after a few stumbles. Cleared the codes and I am good to go. Hope this helps someone who has this problem.
Old Apr 13, 2014
GolNat's Avatar
Prelude Owner
Re: DIY: Draining your fuel tank
glad to hear it worked. Hopefully I won't need to do that but good info.
That could have been a lot worse.
Old Apr 13, 2014
Please be aware that the fuel pump alone usually does not completely empty the fuel tank. There could be as much as a half gallon of liquid (or more) remaining even though the pump quit moving liquid.
Diesel will be diluted by fresh gasoline so hopefully it won't cause problems.....
If there had been water in the tank it could still be a problem.
My 2¢
Old Apr 13, 2014
johndeerebones's Avatar
johndeerebones is a jewel in the roughjohndeerebones is a jewel in the roughjohndeerebones is a jewel in the rough
May still set codes for a bit, regularly had customers do this to gas power equipment when I was in that field (they always had diesel tractors too), and a few gallons of gas dilutes diesel well enough in less fuel. All I know is wow, expensive lesson for her to learn.
Old Apr 13, 2014
kdliberty's Avatar
kdliberty is an unknown quantity at this point
I know several people who have done it the other way. That right they put gas into the diesel vehicle. It happens more then you think . Glad it was not worse...
andyandyy
Aug 7, 2015 07:14 AM
shaejb15
Jul 27, 2015 03:48 PM
Kyles24
Jul 16, 2015 10:14 PM
Kyles24
Jul 12, 2015 09:15 PM
jody501
Jul 10, 2015 11:01 AM
