Alternator rattle
Old Mar 5, 2014
acidpizza's Avatar
acidpizza is an unknown quantity at this point
Alternator rattle
Hello. So I have an 01 LX and every time I start the car to let it warm up, a very annoying and fairly loud rattle comes from the engine bay. At first, I suspected that it was the front engine mount (which was broken) and I replaced it but the rattle is still there. The rattle goes away when accelerating past 2k~ rpm and comes back when idling or until the car is at operating temps(or it just gets quieter to where it is almost unnoticeable). I looked at some maintenance records and found that during a recall inspection back in November the previous owner had been informed that an alternator bolt was loose and causing a rattle. Upon looking under the hood and listening for the rattle, I could tell it was exactly that. I don't know how many bolts the alternator has so I am unsure which bolts are loose or missing, or where I should look and how I should fix the problem.
Any help would be greatly appreciated!
Old Mar 5, 2014
mikey1's Avatar
Re: Alternator rattle
could be your A/C pulley causing that noise rattle,
remove the alternator belt and start the car, is the sound gone?
if so, its your alt or a/c pulley, so you need to figure out which one,
i believe the alt has 3 mounting bolts, but cant quite remember as its been awhile,
Old Mar 5, 2014
Nobody bothered to take care of it at that point in time?
Jeez.
There's one bolt with a 14mm head you get from above, it's just under the PS pump.
Then you go through the wheelwell to find the others on the adjustment bracket.
Old Mar 7, 2014
acidpizza's Avatar
To get to the one from above I will have to remove the pump right? I am a little afraid hesitant because those hoses look important lol. Also, there should be a total of 3 bolts right?
Old Mar 7, 2014
*I* don't have to.
Maybe.
Or maybe not.
As in, what happens if you find the 3 in question already tight? What do you do then?
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Bonobo
Oct 2, 2015 06:58 PM
ken4444
Sep 30, 2015 07:37 PM
rovafa2002
Sep 28, 2015 06:57 PM
260000milesgoal
Sep 25, 2015 07:41 PM
