Intermittent startup and grinding at times
Old Dec 26, 2013
honkeydonkey's Avatar
honkeydonkey has a spectacular aura abouthonkeydonkey has a spectacular aura about
Hi all,
My 02' Civic EX is having a very strange issue where sometimes when you turn the key nothing happens, or it will turn over once and stop, or it will crank right up. Rarely, there will be a grinding sound during startup which i would believe to be the starter grinding on the flywheel teeth. Any help would be appreciated, as I need my car to start reliably.
Old Dec 26, 2013
Re: Intermittent startup and grinding at times
First things to do are the standard electrical checks.......
But I'll GUESS you need a starter.
Inspect the teeth of the ring gear for grinding damage. If there is a lot of damage, then you have a whole bunch of work to do.
Old Dec 27, 2013
would it be possible that maybe it is just loose and that would cause the cables to not have good connections, and that the gears aren't lining up right which would cause the grinding?
Old Dec 27, 2013
If you think that's a possibility, I'll suggest you grab some wrenches/voltmeter/test light, and dig into it to find out if you are right.
I can only guess from where I sit, and I already guessed you need a starter.
HTH
mikemc422
Aug 9, 2018 05:41 PM
ywgflyer
May 15, 2015 05:05 PM
hokiedad4
May 3, 2015 10:06 PM
edgenet
May 2, 2015 08:00 PM
EC3
Apr 22, 2015 07:55 PM
