My friends car is missing an EGR Valve
Old Dec 10, 2013
acidpizza's Avatar
acidpizza is an unknown quantity at this point
I am considering buying my sister's boyfriend's 2001 Civic LX but he told me it has some oil leaking. I youtube'd this problem and stumbled upon this video :
I realized when I looked under the hood of my friends car, that the entire EGR Valve piece was missing. It is as if someone had pulled it out and never put it back in.
Is this something serious/expensive to replace? Is there anything else that may have been affected? New to these forums by the way, any help would be appreciated!
EDIT: I also remember hearing my friend say that he is missing the cap for the coolant reservoir. This may explain the oil leak and nasty smell? After doing some research, I found that the radiator could be damaged as well as a result of the missing coolant reservoir cap.
Old Dec 10, 2013
johndeerebones's Avatar
johndeerebones is a jewel in the roughjohndeerebones is a jewel in the roughjohndeerebones is a jewel in the rough
Re: My friends car is missing an EGR Valve
I doubt it is "missing". It would make some serious noise if it wasn't there along with a check engine light. The D17a1 doesn't have it. That is an a2 in the video. What model is it, ie lx, dx, etc?
Old Dec 10, 2013
Call the cops!
So where's the oil leak?
Old Dec 10, 2013
acidpizza's Avatar
Ah ok. It is an LX and the oil leak appears to be coming from the cap mentioned in the video.
Old Dec 10, 2013
Check this thread https://www.civicforums.com/forums/1...ml#post4651958, there's a catalog link in it.
Or search, this has been covered in the forum several times in the past.
HTH
EDIT: That video covers the replacement rather well.
Old Dec 16, 2013
j.squared's Avatar
j.squared is an unknown quantity at this point
Was the EGR missing or was it just the plastic cap they replace in the video?
Old Dec 17, 2013
crxmanpat's Avatar
Pusher Jets Rule!
crxmanpat has a spectacular aura aboutcrxmanpat has a spectacular aura about
The EGR is not "missing". The D17A1 in the 01 LX did not come with an EGR, only the D17A2 has it.
The cap mentioned is the one that plugs the cam hole where a distributor used to go. Since the D17 went to a distributorless system, the simple fix by Honda was to plug the cam hole with a plastic cap that has an o-ring on it. It is a very common source for a very slight oil leak, and is very simple to replace as pointed out in that video.
ezone
24
Oct 30, 2017 11:27 AM
LionSpratt
Jan 29, 2017 11:07 PM
Blaster30
Apr 22, 2015 12:21 PM
blacklud
Apr 13, 2015 06:15 PM
usajags84
Apr 10, 2015 09:54 PM
