Gears grinding while shifting
Old Nov 28, 2013
mHo2's Avatar
mHo2 is an unknown quantity at this point
Hi there, I have the following problem on my 2002 Civic LX Coupe Manual:
When I upshift or downshift with the clutch fully in I can feel resistance while shifting INTO a gear. If I hold the shifter near this resistance point I can feel gears grinding. It doesn't sound OR feel as bad as a full gear grind but I can feel the vibration from it.
Some other notes:
  • This doesn't occur when my car is stopped
  • This occurs less at lower speeds
  • I can't feel slippage in my clutch, but unsure
  • When my clutch is fully depressed it does not make any noises except for a small squeak while pushing it in (guessing due to water)
  • Double clutching doesn't fix the issue
  • At high RPM's my shifter vibrates as well
Any advice is greatly appreciated as i'm lost as to what it could be.
Regards,
-Mat
Old Nov 28, 2013
GolNat's Avatar
Prelude Owner
Re: Gears grinding while shifting
Could be low on fluid. Did you check?
Noisy clutch pedal is standard. Just need to lube the spring on the pedal.
Old Nov 28, 2013
mHo2's Avatar
Here's a pic of the fluids
https://i.imgur.com/Z2oNNZ7.jpg
The smaller cylinder (i'm guessing clutch fluid) is kinda low, but within acceptable limits. Any further advice?
Thanks.
Old Nov 28, 2013
mHo2's Avatar
Added some dot3 fluid and that didn't help
Thanks.
Old Nov 29, 2013
GolNat's Avatar
Prelude Owner
You need to check the transmission fluid level. There is a bolt on the back of the transmission that has a square insert for a tool. You need to remove that and stick your finger in it and see if you can feel the fluid. I'll see if I can find a pic
Old Dec 2, 2013
pjb3's Avatar
pjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of light
I would start by bleeding the clutch master and slave cylinders. A lot of times when the clutch is not releasing all the way the synchronizers will mask the problem by keeping the gears from grinding but making it harder to engage the gear.
Bleeding the clutch system is cheap so it is one of the first things I would do. Just adding fluid will not solve the problem if the system needs to be bled. The down side is people seem to have problems doing it so I would read up on it first.
Old Dec 2, 2013
That clutch reservoir that is "kinda low": That fluid had to go somewhere.
Check if the rubber boot on the slave cylinder is holding a bunch of fluid.
If that boot is well sealed and can't let leaking fluid dribble out, it can push the slave piston deep into its bore and cause insufficient travel when you push the pedal (and the pedal "feels lower" than it should).
nirvanaguy
25
Oct 26, 2017 07:26 PM
JJ291
Sep 2, 2015 11:49 PM
JetsterDajet
Aug 15, 2015 08:07 AM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
Jul 12, 2015 11:54 AM
