check engine.code P1361
Old Sep 9, 2013
Toms49ers4life's Avatar
My 7th gen civic
Toms49ers4life is an unknown quantity at this point
Hello fellow em2 lovers, i have a 01 civic dx that dies on me in the middle of driving.and.i get this check engine codeP1361 Camshaft Position (CMP) Sensor A (Top Dead Center (TDC) Sensor) Intermittent Interruption is this a hard job? Or an easy fix? Please help guys.
Old Sep 9, 2013
Poopies's Avatar
Super Moderator
Re: check engine.code P1361
http://estore.honda.com/honda/parts/...+10&dl=207697#
Should be #10. Looks like it's behind the timing belt and it could be a bit of a pain.
Old Sep 9, 2013
JJ291's Avatar
No amateur/no professional
JJ291 is an unknown quantity at this point
Hard is a relative term.
This happened to me a few years back. The service manual on Page 11-8 calls this code out as your Top Dead Center Sensor. There are some diagnostics you can do but basically they will just tell you that you either have a bad wire, bad ecu, or bad sensor. IMO it is most likely the 3rd.
If I remember right, the sensor costs about $60-70. You would have to pull the valve cover to remove the top timing cover. After that it is one bolt and you're back in business. I've highlighted the top timing cover on this pic and also the sensor location. The sensor is not shown in the pic but is on the list page for "Cylinder Head" item 10.
Best advice though - order a service manual if you don't have one.
Old Sep 9, 2013
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
Just adding to JJ's post with the picture of the sensor, piece #10
Looks to cost $42.90 plus shipping from majestic honda.
HX
Dec 28, 2001 10:04 AM
Micks2K1
Dec 6, 2001 07:09 PM
delacampos
Nov 7, 2001 09:18 PM
dubbc
Nov 7, 2001 02:24 PM
GoofyLogicInc
Oct 25, 2001 09:50 PM
