misfire codes
Old Aug 14, 2013
Crusader10143's Avatar
Crusader10143 is an unknown quantity at this point
misfire codes
hey all new to the forums here, having some trouble with my 02 civic ex, 5sp only mods are full exhaust and cold air. Got the car from my buddy we did head gasket intake gasket timing belt, new plugs, basically whole top end. Im getting misfire codes, sometimes 1,2 sometimes 1,2,3, or sometimes all 4. replaced fuel filter and tried diff egr and still nothing, car seems to sputter a little at idle too. any input?
Old Aug 19, 2013
Poopies's Avatar
Super Moderator
Re: misfire codes
Recheck the timing? Did it have trouble before you did that?
Old Aug 19, 2013
Re: misfire codes
Timing was dead on when we did it so shouldnt be off, the only thing it did before was if I let it sit in the garage for a day or two the battery would die and when I started it, it would run fine for a minute then start misfiring like crazy but if I drove it down the road it would go back to normal. ive driven the car just about every day since and it stopped doing that on cold starts.
Old Aug 19, 2013
Re: misfire codes
It seems like from the small putts out the muffler at idle its getting gas into the cylinder from maybe a faulty injector but im not positive on it
Old Aug 19, 2013
Poopies's Avatar
Super Moderator
Re: misfire codes
Maybe... sounds like there are electrical problems too. If the battery is old, I'd replace it.
Old Aug 19, 2013
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
Re: misfire codes
Did you clean the EGR passages on the intake when you did the head gasket?
Old Aug 21, 2013
Re: misfire codes
yes, egr ports were so gunked in carbon took me 20 min to clean but I cleaned em. Another update here I took the plugs out last night to check them and cyl 2 plug was pure white and the other 3 were half white. and they didn't smell like anything either no gas or oil. Am I possibly running lean and not getting enough fuel? I changed fuel filter couple weeks ago and those plugs were only a month old so maybe fuel pump going?
Old Sep 6, 2013
Re: misfire codes
bump
Old Oct 22, 2013
carolinacivic's Avatar
carolinacivic is an unknown quantity at this point
Re: misfire codes
Have you had the fuel injectors cleaned? It sounds like you have a clogged fuel injector filter basket. You can send them out and have them cleaned and put on a flow bench for $20 at www.racecityinjector.com
Old Oct 22, 2013
SBCivic02's Avatar
SBCivic02 is an unknown quantity at this point
Re: misfire codes
Water got into my spark plugs and i had a ton of misfires, and i could'nt get over 20mph easily. Just saying. Just take a look under the spark plugs and just make sure, or you have they bad spark plugs. If its the coil on plugs, switch coils with another plug and see if the problem follows. Im new to these forums as well so ill just put in my input and maybe it could help.
SimpleUser
Apr 24, 2021 02:54 AM
Civic15
18
Sep 19, 2017 07:48 PM
Green02civic
Jul 27, 2015 10:48 PM
Dani1993
Jul 24, 2015 09:02 AM
NROD315
Jul 21, 2015 07:46 PM
