New radiator, always have to top off coolant
I recently put a hole in my radiator and I let the car get a little hot (2/3 up on the gauge), and after putting a new one in (not oem) the coolant in the radiator always seems to be about a half a cup low, no matter how far I drive, but I haven't went very far without checking and refilling. It just loses that little bit every time. It isn't pushing any into the overflow tank and the temp is staying steady. I'm hoping I didn't blow the HG again when it got hot, but that small amount of coolant has to be going somewhere.
Does anyone think I blew the HG? Thanks
Re: New radiator, always have to top off coolant
Do you see white smoke through the tail pipe? Check the dipstick to see if the oil feels watery. You need to really look around for radiator fluid if you think there is a leak somewhere.
Do an oil change. Look for the dreaded "milkshake" look in your oil. That'll tell you if you're losing coolant internally
7th Gen Civic DIY Enthusiast!
Are you saying you've changed the HG once already? If so, did you get your head checked and machined? If you didn't and you put it back together warped and it over heated again then it may be burning coolant because the heads warped so bad and the HG can't seal correctly anymore.
So update, for the last 150 miles or so, I haven't lost any coolant. I went from losing about a cup per 200 miles to losing nothing. I didn't change anything and I haven't necessarily been babying the car while driving. I'm really confused as to where it WAS going and why it stopped. I'm leaving for college in 20 days and I need to figure out if something is still wrong, especially if I need to pull the head.
lilrob1213
37
Jun 29, 2015 06:45 PM
richgreene
Jun 19, 2015 12:04 AM
Nigel Evans
Jun 10, 2015 06:35 PM
zaboomafoozarg
May 30, 2015 09:21 AM
RallyEX
Jan 24, 2002 11:12 AM
