dumps coolant in resover overheats in 3 days
Old Jun 18, 2015
richgreene's Avatar
richgreene is an unknown quantity at this point
Unhappy dumps coolant in resover overheats in 3 days
Help!!! Stumped big time!!
2001 honda civi 1.7 l engine 140K
Overheats in about three days in hot florida. All of the coolant gets pushed into the reservoir then starts to overheat. Takes about three day to do this.
Here is what has been done to try to fix the overheating.
  • New thermostat
  • New radiator cap
  • Flush and 60/40
  • Sensor for fan is jumped so the fans run all the time
  • Did block/head gasket coolant test stayed blue!
About 5 months ago timing belt, water pump,etc, plugs all changed!
New radiator all new
Ran fine no problems….
Old Jun 18, 2015
Zed's Avatar
Zed
Zed is an unknown quantity at this point
Re: dumps coolant in resover overheats in 3 days
Headgasket.
Old Jun 18, 2015
GolNat's Avatar
Prelude Owner
Yep, headgasket. Common 7th gen issue.
Old Jun 18, 2015
richgreene's Avatar
Headgasket?
I tested it with the coolant tester tool that cover the cap with and the blue stayed blue for 20 plus minutes?
Thanx
Old Jun 18, 2015
GolNat's Avatar
Prelude Owner
Standard HG test won't always catch it. It's a unique problem with this particular engine.
Old Jun 18, 2015
Get it out of Florida.
Old Jun 18, 2015
Headgasket?
Thanx
stop freaking out and start reading.....
https://www.civicforums.com/forums/3...reference.html
it have been tested and the answer is there if you don't freak out....
brats...
Old Jun 19, 2015
alex_nyc's Avatar
alex_nyc is an unknown quantity at this point
at 140k miles youre lucky the head gasket lasted so long
thana
Jun 15, 2020 07:05 PM
blazebrown
18
Jun 2, 2019 12:31 PM
Schneiderman
May 24, 2015 01:14 PM
deus-ex
Apr 13, 2015 12:29 PM
Pongster
Jan 18, 2002 09:30 PM
