02 civic ex automatic shifting issues
Old May 17, 2013
RIPX's Avatar
RIPX is an unknown quantity at this point
Hello,
First time posting here so please bare with me. My father in-law has the option to trade his car for a 02 civic ex. The problem is that it's an automatic which has a shifting issue. Shifting from 3rd to 4th it apparently has a "soft" shift as I would call it. What it does when it's supposed to make the shift is like it's in neutral for a moment then shifts.
I made the recommendation for him to trade his car an 2001 chevy impala for it because he told me it had a "hard" shift which I figured was just high line pressure for whatever reason but not a big issue. A soft shift on the other hand is a whole nother issue and unless I can get some ideas on what could cause this then im going to have to recommend that he stay away from it.
car has about 120k on it, also it had the trans fluid flushed, changed and new filter put in it today and still does it unless you lift before it shifts. Any ideas?
Old May 18, 2013
mikey1's Avatar
Re: 02 civic ex automatic shifting issues
these transmissions do not have filters, so the filter was not changed,
these transmissions should never be flushed, only drained and filled with OEM honda fluid, flushing these trannys will do more harm than good,
i dont think there is any hope for the tranny you describe, it will not get any better no matter what you do, only worse, and will need to be rebuilt or replaced sooner or later,
however i have heard of these trannys lasting many years after showing symptoms of failure so there is no way to tell how long it will last, could fail next week, or it could stay the same for 5 years, its your money and your gamble
Old May 18, 2013
If someone wanted it fixed here, it would get a factory reman trans.
If you want it rebuilt or done cheaper, you can go be pissed at someone else.
Old May 18, 2013
RIPX's Avatar
Thank you, this is what I was afraid of. I told him to stay away from it, while his Chevrolet doesn't get near as good of gas mileage, it doesn't have shifting issue either, so to just stick with it until he can find something else.
Wish they still made Geo Metro's ROFL.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
alexkharden
Apr 23, 2015 07:13 PM
McD
Apr 22, 2015 05:28 PM
chgofirefighter
Apr 18, 2015 08:08 PM
Daniel420
Nov 9, 2001 08:36 PM
