Battery or Fuel issue?
Old May 15, 2013
Hondasouth's Avatar
Hondasouth is an unknown quantity at this point
I'm planning to take my car in to get it checked out this afternoon. It's a 2005 civic with 157K miles.
  • A few days ago I noticed that it took maybe one or two extra cranks for it to fire up in the morning. I didn't think much of it since the issue seemed to resolve itself throughout the day.
  • Yesterday morning it took even longer...I thought, OK, now I need to start troubleshooting. I read that this could be a problem with the battery, fuel pump, starter....or something else. I went home and cleaned up the battery terminals hoping that was the fix. (the battery was installed in Sept 2008 btw)
  • This morning I go to start it and again it's slow. But this time as the engine was finally turning over I noticed that all my instruments/needles shook like crazy for 2-3 seconds. I drive a mile or so and stop in for coffee. I start the car again (after a 5 min stop) and the car starts up normally...maybe 2 turns of the engine.
So battery? Since the starting issue resolved itself after a 1 mile 3 min drive this morning, should I be looking at something else?
Thanks everyone
Old May 15, 2013
Re: Battery or Fuel issue?
You talkin about extended crank time, or are you talkin about slow crank speed?
5 year old battery? Get it tested.
Cheapo? Could be....sulfated.
Did someone leave a dome light on?
Is the AC compressor clutch stuck on?
Could have a slow drain on the system.
Those cars usually have a draw of about 20 milliamps or less. If the car is stock (electrically) and the draw is more than 50mA then something is probably going on.
Long crank time: Does it do this with a full tank of fuel? Seems like a lot of these cars crank longer when the tank is lower than about half.
Old May 15, 2013
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
I had a similar issue about a year ago, maybe longer. It ended up being battery. I took it to O'reilly's where I bought it and the guy testing said it had low CCA's. It was at like 350 vs the 500 CCA's. I was pro-rated, new battery and have been good ever since.
CarStuff
Dec 6, 2020 12:52 PM
dpru
May 26, 2015 07:01 PM
McD
Apr 29, 2015 03:50 PM
tylerginevan
Apr 27, 2015 12:29 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
