Oil Leak PCV Valve
Old Apr 26, 2013
mlandmann's Avatar
mlandmann is an unknown quantity at this point
Oil Leak PCV Valve
I have concluded that I have an oil leak in my 05 civic ex. After closer inspection it appears to be coming from the PCV valve area. I took pictures from under the car which are attatched. I do not think it is coming from above the PCV valve area. However, I would be interested to hear if anyone thinks different.
Old Apr 26, 2013
mikey1's Avatar
Re: Oil Leak PCV Valve
a clogged or plugged pcv valve can cause oil leaks,
when is the last time you replaced it?
LionSpratt
Jan 29, 2017 11:07 PM
RIPSAW
Nov 6, 2015 04:36 AM
671civicLX
Jun 13, 2015 05:56 PM
Bradel26
May 30, 2015 10:24 AM
davidpaustin
May 20, 2015 12:59 PM
