Power window issues
Old Apr 12, 2013
O6hook1's Avatar
O6hook1 is an unknown quantity at this point
Power window issues
I need some help. I have a 2001 civic ex 2 door coupe. I am having issues with my passenger side power window. It rolls down but will not roll up. I have checked and replaced all fuses, replaced the switch on the door, replaced the motor and track, replaced the power window relay, and still nothing. The switch on the pass. door will activate the motor to go down, but not up. the master switch on drivers door will not do anything up or down. I don't have any blown fuses, the relay is working, I have power coming of both the master switch, and the door switch. According to the wiring diagram there is a window control unit (that is integrated into the master switch) and a main switch(this I have no idea what it's for or where it's located. I also can't find any info about it anywhere). The wcu I have found is not found in all models. Does anyone have any ideas or suggestions on what it could be. Also need help trying to locate the main switch? I doubt it's the main switch. I read that it can get wet and short out. It happened in the middle of winter so the switch has to gotten wet. Any help would be appreciated.
Old Apr 12, 2013
O6hook1's Avatar
Re: Power window issues
I've also unplugged the master switch to see if the child lock was sticking and nothing. The new motor/regulator, switch, fuses, and relay has no change on the window. I have 12V coming off the master switch to the pass. switch on both sides of the switch. I also have 12V coming off the pass. switch going to the motor on both sides of the switch. Full continuity between master and door switch as well as between switch and motor. So no breaks in the wire. Only driver of this car. Rarely have passengers so passenger door is rarely ever opened.
Old Apr 12, 2013
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
The main switch is in the driver side panel..
This is not for your car, however it shows you the panel..
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
beveragemp
May 25, 2015 07:11 PM
got2kids
May 9, 2015 06:45 PM
