2002 Civic EX transmission
Old Mar 22, 2013
gman1868's Avatar
gman1868 is an unknown quantity at this point
Over this past winter the transmission behaves abnormally when started up cold.
Normally when shifting from neutral into drive, there is a single surge as it engages. When cold it engages two to three different times before staying engaged. If the accelerator is pressed between the surges the car doesn't move.
Once it engages it operates normally. It only does it when cold.
Does this mean the pump is going bad? Any other suggestions?
Old Mar 23, 2013
mikey1's Avatar
Re: 2002 Civic EX transmission
how many miles on the car?
how often do you change the tranny fluid?
when was the last time you changed it?
what type of fluid did you use?
is the fluid level full now?
Old Apr 22, 2013
gman1868's Avatar
118,000
Every 20,000
Honda brand fluid
Yup
Old Jun 6, 2013
palsana's Avatar
palsana is an unknown quantity at this point
do you replace it with Honda Transmission Fluid every 20k mi.
CarStuff
Dec 6, 2020 12:52 PM
usajags84
May 10, 2015 08:11 AM
smmahan
Apr 15, 2015 08:17 PM
jonavin
73
Oct 4, 2004 07:18 PM
CapYoda
Nov 11, 2001 05:17 PM
