2002 honda civic ex 1.7 vtec phantom misfire
ok, hello to all. i have a 2002 civic that shows misfires on all cylinders on my scanner in high rpms but the car runs smooth. i have been working on cars for 20 years and no what a misfire feels like. since this is a civic forum i figured somebody here may have heard of this and know a fix. i have checked timing, adjusted valves replaced the vtec solenoid and pressure switch and have verified it working. tested for head gasket, good fuel pressure, new denso plugs, could all four coils be it? thought that unlikely. its only in high rpms, but no change in performance. any suggestions? computer?
Re: 2002 honda civic ex 1.7 vtec phantom misfire
I hate working on things, that's a drag.
I like to fix them.
If you have been working on cars for 20 years, then you should have no problem obtaining and posting the:
Actual fault code number(s).
Freeze Frame data.
Thanks.
Honda Parts for Sale!!!
"you can look up your parts here at www.torontohondaparts.com"
"buy parts online at www.canadianhondaparts.com and use coupon code super20
at the checkout and receive a 20% discount on you order"
Re: Honda Parts for Sale!!!
on my civic 2003 ex it shows misfiring on all 4 cylinders. I just replaced new OEM spark plugs for this vehicle at 178,000 mi and its been driven only about 5k mi & is still showing to be an issue. Before it had engine light code P1505 and then P0730 TRANNY DIFFERENTIAL GEAR and my check engine light has never gone away.
I also notice a brake light appears intermittently above the fuel gauge along with the SRS light? what does it signify?
jessicakaybby
Apr 20, 2015 12:11 PM
ashleymmackey
Apr 18, 2015 09:48 PM
