2001 civic lx manual transmission question
Old Feb 9, 2013
sw civic's Avatar
sw civic is an unknown quantity at this point
Hey guys, I've noticed lately that when shifting (manaul transmission), sometimes I'll notice some resistance when trying to get it to go into gear. It's not all the time and it's not always the same gear. I thought that it may be because of the cold weather but now I'm thinking that it may be something else. Possibly low transmission fluid or bad clutch? Anyone have any insight or has anyone experienced the same problem? The car is a 2001 lx.
Old Feb 9, 2013
clinton_hedrick's Avatar
clinton_hedrick is an unknown quantity at this point
Re: 2001 civic lx manual transmission question
Originally Posted by sw civic
\ Possibly low transmission fluid or bad clutch?
A bad clutch wouldn't have anything to do with difficulty getting it into gear. Check your fluid, and if you haven't done so lately (if at all) change it
Old Feb 9, 2013
Low clutch fluid will let the pedal feel "low" and not completely disengage the clutch when the pedal is pushed.
Refill the reservoir with DOT 3 Brake Fluid if it is low or empty. Pump the pedal several times, hopefully it will come back to normal without other work. Then look for where the lost fluid went.
mattdoc
Mar 14, 2017 12:10 PM
vtechcivic
Apr 21, 2015 07:11 PM
lilbluecivic
Nov 7, 2001 06:49 PM
liljoe
Nov 4, 2001 01:27 PM
HitlistCivic01
Oct 27, 2001 07:47 PM
