2001 honda civic LX transmission problem
Old Feb 2, 2013
theteju's Avatar
theteju is an unknown quantity at this point
Hey guys,
I am not a mechanic but have done some work on civic. My car has issue. it is an automatic trans. It does not go move on drive even if I hit the gas padel. It does the same on reverse gear.
Someone told me, it has to be transmission.
What are my options?
how much money damage am I looking at?
for a long time, I wanted to have a manual transmission. Is this the time to go for that option? the car has roughly 130k miles on it. timing belt was changed around 90k.
Any replies will be highly appreciated. Thanks in advance.
Old Feb 2, 2013
mikey1's Avatar
Re: 2001 honda civic LX transmission problem
a fairly common problem.....you can look at having a used or rebuilt tranny installed which will probably be at least $1500, or sell the car as it is
Old Feb 2, 2013
Does the speedometer show any speed when you do this, or just lay on zero?
If it stays on zero, you need a transmission job.
If it moves, then you should have an axle or CV joint problem.
Old Feb 2, 2013
theteju's Avatar
hey, guys, thank you very much for reply. I been waiting for the reply. I tried the forum and DIY sticky does not work. !!
I think the speedometer moves, I paid attention to rpms never at speedometer. I will check when I get home.
How much the manual tranny cost? any recommended website/seller to buy?
Old Feb 5, 2013
theteju's Avatar
The speedometer lay on zero.
Update: I got a mechanic run the engine core and the code we got is P0730.
Something about inaccurate gear pressure. I am looking towards a selenoid valve A/B replacement.
any comments?
Old Feb 5, 2013
mikey1's Avatar
Originally Posted by theteju
any comments?
rebuild or replace the tranny
Old Feb 5, 2013
Incorrect gear ratio.
That's a "code of death" for these. It would get a trans replacement here.
Old Feb 8, 2013
theteju's Avatar
currently what kit is recommended. I read posts and it appears for 2001 auto TCI used to make best rebuild kits.
What are the options on the market?
Old Feb 9, 2013
theteju's Avatar
Bump...
found this, http://www.makcotransmissionparts.com/S24A.html something should I consider?
I am ready to invest in putting quality parts if I am rebuilding my transmission. Please advise accordingly.
Thank you.
Old Feb 9, 2013
No advice from me on any kits.
At the dealer, we only install reman units.
Old Feb 9, 2013
theteju's Avatar
Code of Death sounds cool, Should be my thread Title. lol.
Old Feb 9, 2013
theteju's Avatar
I can not afford to go to dealer bro ! they are quoting around $3k. Damm.
more kits are on Amazon.
found this http://www.transtar1.com/default.asp
anyone.
Old Feb 10, 2013
Biscuit's Avatar
2001 Civic LX Sedan
Biscuit will become famous soon enoughBiscuit will become famous soon enough
The torque converter clutch has failed and the clutches for the gears are very near failure.
It cost me $2,456.27 for a rebuild.
LionSpratt
Jan 29, 2017 11:07 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
bahena08
Apr 11, 2015 05:09 PM
locozoko
Apr 6, 2002 09:00 PM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
