Dont know where this part goes?
Old Jan 17, 2013
tomg's Avatar
tomg is an unknown quantity at this point
I removed my cylinder head from my 2003 Civic EX. I think these parts fell out of the head when I was taking it off. I cannot post photos so I will describe. Cylindrical piston with spring. Spring is 22 mm long and 8 mm in diameter. Piston is 12 mm diam 52 mm long with counter bor for spring and hole drilled to the center
Old Jan 17, 2013
Re: Dont know where this part goes?
Sorry about that, posted to the wrong thread.
Old Jan 17, 2013
Oooh, gonna need pics or maybe find your parts in a parts catalog.....
Do you know where these fell out of?
Did you take the top (solenoid coil) off of the VTEC valve?
Old Jan 17, 2013
04 Honda Civic's Avatar
This game is hard without pictures..
I really cant think of anything like that that would fall out of the head..
Old Jan 17, 2013
I'll take "Shouldn't have done that" for $200 Alex....
Did you mess with the cam and rocker arms, have one of the VTEC locking pins fall out of a rocker?
Old Jan 17, 2013
johndeerebones's Avatar
johndeerebones is a jewel in the roughjohndeerebones is a jewel in the roughjohndeerebones is a jewel in the rough
Originally Posted by ezone
I'll take "Shouldn't have done that" for $200 Alex....?
ROFL, ya, we need pics
Old Jan 18, 2013
tomg's Avatar
this is it
Old Jan 18, 2013
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
^^^^tomg, can you answer the above?
That looks like a VTEC solenoid piston and spring to me. And you may be missing another piece as well. I can't remember.
If it is the VTEC piston and spring, it goes where the pictures finger is below.
Which is located at the back left of the head as you're looking at the engine from the front.
Old Jan 18, 2013
Woohoo! My first guess was teh winnar!
What do I win? What do I win?
Old Jan 18, 2013
tomg's Avatar
Is this the bottom of the solenoid?
Old Jan 18, 2013
tomg's Avatar
This is a photo i found on the web.
http://www.bing.com/images/search?q=...electedIndex=4
Old Jan 18, 2013
tomg's Avatar
This part is similar but not the exact match. It is the spacer that is missing on my photo. Do you know if the valve I have needs the spacer?
Photos of my valve with piston and spring installed
ID:	84568   Click image for larger version
Old Jan 18, 2013
I think that if you are missing any of its pieces (guts), you are going to purchase the complete valve.
Box #9 is what you buy.
Linky http://www.hondaautomotiveparts.com/...EAD+%28VTEC%29
Old Jan 18, 2013
Matt_75's Avatar
I don't think your missing a spacer. I thought so, but I don't think this gen has a spacer and it sits as shown in your pics. Worst case is you put it back together and VTEC doesn't work and puts you in limp mode. Then you'll need a new valve as ezone pointed out.
Old Jan 18, 2013
tomg's Avatar
I dont think i am missiing the spacer either. The one I have is a different design. The spool is longer and the mating part looks like it has something some cylindrical stop cast into it.
I would be nice to see an assembley dwg or photo before I put it together tomorrow.
Old Jan 19, 2013
Matt_75's Avatar
Install spring and install piston with "counter bor for spring"(as you called it) facing down. Install new o-ring and torque bolts to 7.2 lbf-ft or 86.4 inch pounds.
Old Jan 20, 2013
tomg's Avatar
Thanks for this information
Old Jan 20, 2013
Did you end up fixing it?
mohawkboom
67
Aug 25, 2015 12:28 AM
Tim1959
Jun 3, 2015 08:15 PM
juror
May 26, 2015 06:35 PM
shindrome
Exterior
May 5, 2015 02:50 PM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
