Please help me fix a problem, strange noise
Old Jan 10, 2013
G8rMichael's Avatar
G8rMichael is an unknown quantity at this point
i have a 2004 civic ex and for some reason it just started making a weird clicking sound (hard to explain) but sounds like its coming from my front right tire well and it will go for maybe 30 seconds only while driving, if im stopped i wont hear it. but then after a little bit i wont hear it again unless i turn off my car for a little while and then go again, also i dont know if this has anything to do with it, but it also makes weird humming sound when i reverse (not the normal reverse sound) quite loud and once again will stop if i stop, please help! thank you!
Old Jan 10, 2013
Re: Please help me fix a problem, strange noise
Sounds like nails on a chalkboard? Pad wear indicator squeal?
Old Jan 10, 2013
G8rMichael's Avatar
no its not brake pads, its more like a clicking like tick tick tick but faster and then goes away after i start driving a little bit
Old Jan 10, 2013
CV joint boots split open and lost the grease, joints clicking now?
Just guessing.
Someone knowledgeable ought to drive it, get under it, and take a real look.
Old Jan 10, 2013
G8rMichael's Avatar
so you think i should take it to a place?
Old Jan 10, 2013
That's entirely up to you.
If you can't get under it to look around, then someone else probably needs to.
All I can do is guess from here.
None of us can hear what you hear, and none of us can see your car.
Old Jan 10, 2013
G8rMichael's Avatar
Alright well thank you for your help
roverben
Jan 21, 2019 05:16 PM
jakeconnor
May 5, 2015 07:30 AM
bo_red
Transmission
May 3, 2015 09:14 PM
dooner24
Apr 14, 2015 07:51 PM
05civic
Dec 23, 2001 08:34 PM
