Need help with 2004 Civic Coup EX upstream o2 sensor replacement
Old Jan 9, 2013
xerion's Avatar
xerion is an unknown quantity at this point
Hi guys,
So my engine light is on and I ran a check and the code P0135 indicates that the upstream sensor is bad. I got a new SMP o2 sensor and was going to replace it. But there doesn't seem to be enough space to get my hand to the sensor. This gen of civic has the upstream o2 on the lower right side of the engine exhaust manifold, as opposed to earlier versions which had it right on top. This SUCKS.
Should I remove some parts and attempt to do this from the top, or jack my car up and do it from the bottom? I'm new to auto maintenance and was hoping that some of you more experienced members can help me out.
Thanks!
Old Jan 9, 2013
Re: Need help with 2004 Civic Coup EX upstream o2 sensor replacement
Jack your car up and crawl underneath. SOOOO much easier than trying to do it from up top..
Poopies
Apr 20, 2017 11:36 PM
rtachs
Jul 16, 2015 05:32 PM
hokiedad4
May 3, 2015 10:06 PM
oneheadlight
Apr 29, 2015 11:30 PM
Jeeves
Jan 20, 2002 10:38 PM
