knock/clunk noise? Bad motor mount?
Old Dec 19, 2012
cowley91's Avatar
cowley91 is an unknown quantity at this point
Ok so when I'm driving and making a right turn, as soon as I touch the gas pedal I hear a loud knock coming from the front end of my car. Happens almost every time on right turns. Left turns nothing happens. While driving straight occasional repeated small knocks can be heard when driving over small bumps in the road.
Motor mount?
Old Dec 20, 2012
botakcivic's Avatar
botakcivic is an unknown quantity at this point
Re: knock/clunk noise? Bad motor mount?
I would check the left CV joint.
Replacing the whole axle assembly is rather cheap and easy
GL
Old Dec 21, 2012
mikey1's Avatar
Originally Posted by cowley91
Motor mount?
i would say no.....
a noise when making a right turn normally means a problem in the front LEFT wheel area, have that area inspected, it could be a number of things....C/V joint, ball joints, tie rod end, just to name a few
Old Dec 25, 2012
D Murphy's Avatar
D Murphy is an unknown quantity at this point
Check the axles. Probably a bad outer joint.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Supramk3
May 11, 2015 07:55 PM
Jigee
May 9, 2015 11:18 AM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bsmiley
Apr 27, 2015 01:27 PM
