Accessory Belt
Old Dec 11, 2012
sean2012's Avatar
sean2012 is an unknown quantity at this point
Accessory Belt
Hey guys my a/c is going out and don't have the money to replace it right now. So I was just going to by a belt that bypasses the a/c. I have a 04 civic lx does anyone know what size belt I would need? The belt would be running from the engine to the alternator. Thanks.
Old Dec 11, 2012
mikey1's Avatar
Re: Accessory Belt
what do you mean by "going out"?
do you mean your a/c does not work?
or your a/c pulley is seizing up and its making noise while it turns?
if there is no noise, just get the standard belt and have it run around the a/c....its just free spinning when the a/c is not on
Old Dec 11, 2012
sean2012's Avatar
Re: Accessory Belt
I believe it is seizing up because it makes a dreadful sound every now and then.
Old Dec 11, 2012
Re: Accessory Belt
This was hashed in a thread a week ago. You are welcome to use the search function on this site.
Alt belt for a DX (no AC) is 31110-PLA-E02, about $20 MSRP USD (honest dealer retail) and probably would need to be special ordered.
Also, DangerZone apparently can have it. http://www.autozone.com/autozone/par...62_0_1527_6774
Old Dec 13, 2012
04 Honda Civic's Avatar
Re: Accessory Belt
Is the pulley seized? Why not just leave the a/c button off?
Am I missing something here?
Old Dec 19, 2012
sean2012's Avatar
Re: Accessory Belt
Even when it was off it would still make noise. Anyways thanks for the belt suggestions. I did not use that belt though. I measured the size I needed which was around 875mm so I bought a 6 ribbed belt from Napa that is 873mm which fits perfectly. No more squeaking!
Old Dec 20, 2012
Re: Accessory Belt
Good to hear.
Dave1984
Jul 22, 2015 06:10 PM
Ariah J. Davis
Jul 20, 2015 07:15 AM
1khilari
Jul 9, 2015 08:12 PM
