Daytime running light
Old Dec 9, 2012
dammuzi's Avatar
dammuzi is an unknown quantity at this point
ok so i had a DRL out
replaced the bulb with same make/model as before now neither come on
replaced fuse even though it was not out still no drl
headlights and brights work fine
thinking next step is the relay unless someone here has a better idea, unless there is a reason why i need to replace both when one is out?
Old Dec 9, 2012
Re: Daytime running light
DRL control unit is where I would start my testing.
Last one I saw needed everything on the circuit board resoldered. Easy if you can solder.
Old Dec 10, 2012
CraigW's Avatar
What year ?
Old Dec 10, 2012
cb450sc's Avatar
cb450sc is an unknown quantity at this point
When I had my 2003 I had to resolder the circuit board. It was an easy fix. An alternative may be to get a used unit.
Old Dec 24, 2012
dammuzi's Avatar
figured i would update with results. applied Occam's razor and started by replacing both bulbs at same time. Fixed
werdnahall
May 17, 2015 11:37 AM
eorlando1
May 17, 2015 11:16 AM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
supercivic01
South
Nov 30, 2001 11:27 AM
cazminn
Nov 9, 2001 11:18 AM
