hard staring once warm and once started white smoke
Old Dec 6, 2012
dem0nk1d's Avatar
dem0nk1d is an unknown quantity at this point
rebuilt block, all new gaskets, seals the whole 9. now i've finally got this new engine running. first failure was the intake manifold was slightly different than the oem version. the gasket i used didn't have the holes for the egr passage way in the intake manifold flange. once i discovered this was an issue i changed it out with the old gasket. Now once changed out i got rid of the Egr flow code P401. Success!! Drove it around the block, and then had to bleed the coolant system of some air. No biggie...
On cold start ups no issues at all. But once the engine has been ran for sometime and lets say i make quick pit stop and hop back into the car. It has a very hard time starting. All most like to much fuel, but once it starts after giving it some gas there is a nice white cloud of smoke... So what do you think it could be? Where should I look next?
Old Dec 7, 2012
mikey1's Avatar
Re: hard staring once warm and once started white smoke
hard starting when warm is sometime the result of a poor ground, check all your ground connections for rust and/or corrosion
Old Dec 7, 2012
dem0nk1d's Avatar
once it starts, as it seems like it's flooded.... it will fire up idle terrible, i have to give it gas, then evens out... but white smoke. i would think the headgasket didn't seal properly.
will have to do a leak down test, or at least a compression test
**is it possible the gasket on the side of the head that houses the egr valve and the thermostat is leaking into the EGR valve? i'm wondering if this is possible. **
Old Dec 7, 2012
GolNat's Avatar
Prelude Owner
Yea, I would check your head gasket. White smoke would be your coolant burning off, and since you just did that, it might have not seated properly.
Old Dec 7, 2012
dem0nk1d's Avatar
is there a max torque setting you guys recommend for the head gasket? The head was machined, and the block decked, bored, honed, new bearings etc... So i know both surfaces are perfect. No signs of over heating.
Old Dec 7, 2012
mikey1's Avatar
the head bolts need to be torqued gradually and evenly in a specific pattern until you reach the final torque spec, not sure off hand what that is, dont have my manual with me,
you should be torquing them gradually though, like all of them to 5 foot pounds, then all of them to 10 foot pounds etc etc,
Old Dec 7, 2012
dem0nk1d's Avatar
Old Dec 8, 2012
dem0nk1d's Avatar
i guess what am i asking is can i go over the recommended setting of 49, thinking maybe add 2 more lbs and maybe it will fix the issue.
Old Dec 9, 2012
mikey1's Avatar
no i dont think that will help,
you will be risking stripping the bolts and/or crushing the gasket,
did you torque them gradually in the pattern?
Old Dec 9, 2012
dem0nk1d's Avatar
i went by the book, from a-z. so yes i torqued them correctly. i pulled the head this afternoon. found some milky residue in the valve cover. so the guys on the d-series recommended going 100% oem headgasket, and this should fix the issue. also couldnt find signs of failure with the used / new gasket only 200 miles on it.
Old Dec 9, 2012
dem0nk1d's Avatar
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
thana
Jun 15, 2020 07:05 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
crowtoo
May 11, 2015 06:50 PM
cooldan1
Apr 23, 2015 10:49 AM
