auto tensioner does it need 2b replaced
Old Nov 30, 2012
dem0nk1d's Avatar
dem0nk1d is an unknown quantity at this point
So rebuilt this d17a1 and installed everything new but the auto tensioner. Does this need to be replaced if you can still tighten the belt down correctly?
My method doesn’t even use the grenade pin.
1.) Loosen and install the Auto Tensioner
2.) Disconnect Spring
3.) Install belt
4.) Install AT spring
5.) Rotate counter clockwise
6.) Tighten AT bolt
7.) Call it a day
Old Nov 30, 2012
mikey1's Avatar
Re: auto tensioner does it need 2b replaced
you need to use the grenade pin method,
with the belt removed....
- line up the two holes in the tensioner and install the grenade pin
- tighten tensioner bolt snug, then loosen the bolt half turn
- install timing belt
- install tensioner spring
- rotate crankshaft TWO revolutions and check TDC marks again
- tighten/torque tensioner bolt to spec
- remove grenade pin
those are the steps that should be followed
the tensioner will last a long time but not forever, so you just need to guage it yourself....i replaced my tensioner and water pump at 240,000km even though both items were still functioning fine
Old Nov 30, 2012
dem0nk1d's Avatar
I guess so, i don't see the need for the gernade pin, it doesn't hold the tensionor back for me...
Old Nov 30, 2012
mikey1's Avatar
it lines up the positioning of the tensioner base on the block
Old Nov 30, 2012
dem0nk1d's Avatar
i still don't see the need for it if you can create the tension into the belt that is needed and snug the tensioner into place. But I guess Honda is always right! I'm just pissed i have to tear apart everything to get to the damn t-belt. I wish this engine was a true D-series and not this whole redesigned crap. D17 in my book is the worst design they did. Especially the A/C line going directly over the engine.. Smarts i tell you.
Old Nov 30, 2012
mikey1's Avatar
the tensioner can still move after the bolt is tightened
where else could they put the A/c lines? Under the engine?
Old Nov 30, 2012
dem0nk1d's Avatar
88-00 had hard lines that were tucked against the fender rails and then across the radiator support. IDK maybe i'm old school now and can relate to the old school v8 guys, where they are like i just don't understand these new ideas. LOL!
88-00 4LIFE =P
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Sep 27, 2015 11:33 AM
Skunkone
Sep 24, 2015 04:38 PM
bashea
Sep 15, 2015 04:59 AM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
