O2 Sensor: Upstream... DIY? Inexpensive parts?
Old Nov 2, 2012
NCCivicNoob's Avatar
NCCivicNoob is an unknown quantity at this point
Hello, my inspection was due October and I couldnt get it due to outrageous tint laws. I finally had time to take it off today and on my way to the inspection center, My engine light comes on. Got the reading, its the Oxygen Sensor, upstream. I really dont know what that is, but nevertheless, I got a price for the part: $250! I dont know if there is a cheap fix i could Do It Myself, or do I have to suck it up and get it done through a mechanic. Ill take any opinion at this point and Doing it myself would be nice, if I can. Thanks!
Old Nov 2, 2012
Re: O2 Sensor: Upstream... DIY? Inexpensive parts?
Anything can be DIY if you have the right equipment.
The hex on an O2 sensor is 7/8 inch.
Upstream is first in the exhaust stream, the sensor closest to the cylinder head.
Old Nov 2, 2012
Aetoc's Avatar
Aetoc will become famous soon enoughAetoc will become famous soon enough
Yea, the OEM sensor is gonna be that expensive, but replacing it is pretty much just a matter of unplugging the old sensor and unbolting it from the exhaust, then doing the opposite with the new one.
Old Nov 3, 2012
04 Honda Civic's Avatar
EX or LX?
Buy a quality one or you WILL be doing it over.
Old Nov 3, 2012
Hello guys! Thanks for the input, and it was all helpful. I went searching for alternatives to this predicament and tried various things before buying the part. I checked the sensor for any loose or frayed wires. They were good. Then I went to the fuse box (inside the car under the steering wheel, second fuse, 20A) and pulled it out and found it good. When I cranked my car up though, the engine check light was off! So I didnt have to buy anything and it passed inspection! I hope I could help anyone that has this problem in the near future! Thanks for replying again!
Old Nov 4, 2012
em2maxamillian's Avatar
em2maxamillian is an unknown quantity at this point
I had the same experience with my upstream O2 sensor, and $250 was around the price I paid for a Denso brand, which I think is the brand Honda uses in their cars anyway. Just a word of caution: keep an eye out for that CEL. My O2 sensor problem was intermittent; meaning that the light would stay off for a few days, come on again, then go off again for a few more days.
Old Nov 6, 2012
I dont think that means your out of the woods just yet, perhaps you pulling the fuse made it reset.
Only time will tell. Good luck.
Old Mar 30, 2013
Thanks for the replies! As for the code, it was showing that there was no conductivity between the sensor and the computer, which I guess means that sometimes it does not get current. Yes the check engine light does still come on every now and then but it always finds a way to turn itself off. I guess I won't switch it until I get a reading that it does not sense an actual flow not conductivity.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
shindrome
Exterior
May 5, 2015 02:50 PM
bsmiley
Apr 27, 2015 01:27 PM
CivicVoz
Apr 16, 2015 08:07 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
