Timing Belt Tensioner Question
Old Oct 18, 2012
mikey1's Avatar
a question out of curiousity....
just wondering what the little hole is for in the back of the tensioner?
it looks like this hole should fit over a dowel in the block or something but it does not and there is no dowel,
i have attached a pic and circled it,
Old Oct 23, 2012
JJ291's Avatar
No amateur/no professional
JJ291 is an unknown quantity at this point
Re: Timing Belt Tensioner Question
mikey1.
So, I'm trying to look at this from an engineering perspective...which is probably the wrong perspective, but I'm going to say...a vent hole to prevent condensate from building up and causing corrosion?
Old Oct 23, 2012
JJ291's Avatar
OK, another thought. Maybe it's used by the OEM during the build process of the autotensioner. They use a dowel to hold that piece in place while they fit the pieces together or something.
Old Nov 4, 2012
Funkcrusader's Avatar
Learning in progress
Funkcrusader is an unknown quantity at this point
i could be wrong, but i believe i read that somewhere too, makes it easier for u to DIY.
Old Nov 6, 2012
04 Honda Civic's Avatar
Its to pin the tensioner before installation.
Once you pull the pin it tightens the timing belt.
Edit:Just realised you werent talking about those holes.
I am not too sure.
Old Nov 6, 2012
mikey1's Avatar
yeah that kind of makes sense
Old Nov 12, 2012
HD~Silverado's Avatar
HD~Silverado is an unknown quantity at this point
Pretty sure you are talking about where the "grenade" pin goes that let's you install the tensioner and install the belt with the tensioner retracted.
Old Nov 13, 2012
mikey1's Avatar
no not the grenade pin hole, the hole in the back of the tensioner.....i have circled it in red in the picture in my first post
dosmastr
May 5, 2015 12:19 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bsmiley
Apr 27, 2015 01:27 PM
dano2005
Apr 14, 2015 01:58 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
