Engine struggling a bit at idle
Old Oct 14, 2012
MarkoPollo's Avatar
MarkoPollo is an unknown quantity at this point
Not sure if its a sensor issue or maybe the alternator is packing it in but when my car is at idle it slowly by steadily has a bit of a hum, or a whir, that deepens in pitch and then the rmp kicks up a bit and then slowly (over bout 40 seconds) starts to drop in pitch untill the rmp kicks up again.
The hum is similar to when the steering wheel is cranked all the way while idling and the power steering pump starts working to circulate but the sound is slightly different.
Old Oct 14, 2012
mikey1's Avatar
Re: Engine struggling a bit at idle
are you getting any warning lights?
listen around the alternator and timing belt cover, it could be your water pump also, although that should not cause rpms to drop
Old Oct 14, 2012
Unplug the 4 wire connector from the alternator so it can't charge. If the sound goes away then it's the alt causing it.
Does it stink too?
Old Nov 20, 2012
MarkoPollo's Avatar
I'll try the 4 wire connector tomorrow.
Old Dec 29, 2012
MarkoPollo's Avatar
Did the timing belt and replaced the water pump. The hump is gone and it's much more quiet but the rpms are still slowly bogging down and then kick up high.
Next up is to check the alternator.
mikemc422
Aug 9, 2018 05:41 PM
beneditti
Jan 15, 2016 12:31 PM
ywgflyer
May 15, 2015 05:05 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
gabrown2
Apr 11, 2015 08:22 PM
