front links
Old Oct 10, 2012
dred's Avatar
dred is an unknown quantity at this point
front links
I got a 1200km road trip planned next week.
so this weekend i jacked up the ol civic and checked my
tie rods and stuff and noticed I can push my front sway bar
links quit easily.
I can't see them doing much like that.
Should I replace them before the trip?
Will they snap off or just get sloppier I guess is the question.
I see there are many after markets and a set of hondas are 100 bux.
Old Oct 10, 2012
Re: front links
links
That statement alone doesn't tell me anything.
You can push them around as far as the sway bar will allow flex. Normal.
The links will pivot a bit; they use ball-and-socket type joints. Normal.
If they aren't causing pop noises, and don't have free play in the joints, they are fine.
Old Oct 10, 2012
dred's Avatar
Re: front links
i mean when i use palm of my hand and push on it i can push it
over easy
I realize it should move but if it is that easy wow what is it doing.
Old Oct 10, 2012
Re: front links
Sounds like you are merely flexing the sway bar.
That is nothing more than a tubular, shaped spring.
It is supposed to flex.
It HAS to flex.
The sway bar is also mounted in rubber bushings, and you may be able to slide the entire bar sideways a little on some cars.
Normal.
Old Nov 3, 2012
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
Re: front links
So I have a popping noise on the down side of a speed bump on my driver side and when I push on the sway bar link joint on my driver side, it moves freely. Are the joints suppose to spin a little or not at all?
Old Nov 3, 2012
Re: front links
They are free to pivot, rotate, spin, twist, and move.
But there should not be free play that allows them to POP.
Grab the sway bar itself right at the very end where the link attaches, push/pull straight up and down....is there free play? If they were the source of a pop noise, you would feel it. (both wheels must be at the same height or dangle so the bar it unloaded)
Old Nov 3, 2012
Matt_75's Avatar
Re: front links
Good to know.
Will do. I wasn't sure how to really check them. Thanks for the advice.
Old Nov 3, 2012
Matt_75's Avatar
Re: front links
So stabilizer links seem solid, but.....I did find this. These were replaced once already in '07. I guess it's more of a thunk than a pop. I'm thinking the control arm is hitting the frame and that's the thunk I'm hearing over a speed bump.
Driver's side
Passenger side
I already called the dealership I would take it too. It's more cost effective parts and labor wise to let them press them out then it is for me to buy 2 lower control arms from majestic. I don't have access to a press.
They told me I should have a wheel alignment done, but I have the option not too. At $90 for the alignment, will these torn bushings effect the alignment that much? I'll spend the money, I just want to know if it's really necessary.
Old Nov 3, 2012
Re: front links
You should be able to push the arms up and down over those bushings and make contact with the subframe, yeah that would be a noise.
Crappy roads much?
The original struts always were a good candidate for being noisy too.
Yes on the alignment.
Old Nov 3, 2012
Matt_75's Avatar
Re: front links
Yeah, I could pull the driver side up and make contact with the frame.
Crappy roads much?
6th worst in the nation.
http://www.mainstreet.com/slideshow/...worst-roads-us
Will do.
I just called the dealership again and ask them if they would install the bushings from the below link. They said they would. I'm thinking these won't rot away yet again in 5 years like these ones did. I'm always for OEM, but I think the below product is probably superior to the OEM bushings in this case.
Amazon Amazon
Old Nov 4, 2012
04 Honda Civic's Avatar
Re: front links
If your tires are wearing uneven you should get an alignment.
BTW if your creative you can do those bushings yourself.
I dont have a press, but had some pipes laying around and a vise.
With some common sense, and being careful, along with small pieces of pipe to fit over the bushing you can get it done.
I am pretty sure I have saved myself $100+ by doing that.
Three+ years later and they are still ok.
Honda rubber sucks.
Old Nov 4, 2012
Matt_75's Avatar
Re: front links
My tire are not wearing uneven as far as I can tell.
BTW if your creative you can do those bushings yourself. I dont have a press, but had some pipes laying around and a vise. With some common sense, and being careful, along with small pieces of pipe to fit over the bushing you can get it done.
Agreed, but I don't have some pipes laying around or a vice. I do have common sense, a parking stall, an apartment and a very small padio with a small tool box.
I am pretty sure I have saved myself $100+ by doing that. Three+ years later and they are still ok.
Good for you. I'd do the same if I could. I was happy I probably saved 600-800 mcdoubles(ezones term for money) in labor cost doing my own head gasket job.
Honda rubber sucks.
1000% agree, at least in the case of these compliance bushings.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
hans.pcguy
Jul 12, 2015 12:19 PM
jbdewitt
Jun 16, 2015 01:36 PM
mrohitredd
Jun 9, 2015 06:37 AM
bsmiley
Apr 27, 2015 01:27 PM
