Car jerks when I release clutch in first and second.
Old Oct 3, 2012
KNIEVO's Avatar
KNIEVO is an unknown quantity at this point
The whole front jerks in 1st and 2nd and just started today. Any ideas? It is a 2003 Civic LX manual.
Old Oct 5, 2012
04 Honda Civic's Avatar
Re: Car jerks when I release clutch in first and second.
How long you been driving manual for?
Old Oct 5, 2012
Thaik's Avatar
Thaik will become famous soon enoughThaik will become famous soon enough
Yeah that's a good question.
Maybe you're releasing the clutch too fast?
It happenned to me too when I switched cars.
Every clutch is different, even from the same brand, model, since it doesn't have the same wear.
Old Oct 8, 2012
KNIEVO's Avatar
5 years
Old Oct 8, 2012
Genez's Avatar
Genez is an unknown quantity at this point
When you say, 'jerks?' You mean it lurches forward? Or, its jerky in how it accelerates? Could be what is called "clutch chatter." Do a Google on it.
I once had it. Honda was talking about changing the clutch.. It went away on its own for some reason. It started when I was in stop and go traffic for a long time one day..
Old Oct 10, 2012
scooty's Avatar
scooty is on a distinguished road
Yes this happens to my car as well occasionally in pro longed stop and go traffic.
Here's hoe to fix it, get on the interstate at around 75 and 5th gear. Lightly push the clutch in so that it just starts slipping. Hold it there for a few seconds, repeat a few times.
Be careful as this will also cause a LOT of clutch wear very fast if you're too hard on it.
Old Oct 11, 2012
Genez's Avatar
That's interesting. You're actually grinding off the high spots that way?
I did not do that, but it may explain how it eventually just went away on its own. I always try to get my foot off the clutch as fast as possible after shifting. I think while I was getting the chatter I instinctively was not engaging the clutch as fast as I usually would to avoid the jerking as much as possible. That may have ground it down because of that.
Old Oct 11, 2012
Outside of the clutch surface, that was already mentioned, I dont think it can be an easy fix.
bsmiley
Apr 27, 2015 01:27 PM
carhag2000
Apr 25, 2015 01:33 PM
Blaster30
Apr 22, 2015 12:21 PM
Guy01
Nov 6, 2001 03:25 PM
CiViCPrAnInG2k1
Nov 1, 2001 03:47 PM
