Code 1259
Re: Code 1259
The computer did not detect a change in the VTEC oil pressure switch when it tried to activate the VTEC valve.
One common cause is low oil level in the engine.
Several other possible causes too.
HTH
HTH
Re: Code 1259
first check oil level, make sure its at the full mark on the stick. if it is, next step is dismantle the solenoid and clean the mesh filter screen. if that doesnt work, replace the solenoid. i finally had to replace mine and it fixed the problem. cleaning the screen sometimes works, but might only be temporary.
Civic15
18
Sep 19, 2017 07:48 PM
Dangerousjordan
Jul 30, 2015 11:19 AM
jessica19699
Jul 29, 2015 05:51 AM
Green02civic
Jul 27, 2015 10:48 PM
