vtec swap almost done, but not starting
Old Aug 8, 2012
02Civicstock's Avatar
02Civicstock
02Civicstock is an unknown quantity at this point
i got all done swappimg in newer motor with vtec head but now i am not getting spark or fuel. the wiring harness and ecu are out of automatic and of course im running my old 5spd. when i put old manual ecu in i get nothing, when the automatic ecu is in, it cranks but no spark or fuel... and ideas guys..?
Old Aug 9, 2012
rjones7755's Avatar
Re: vtec swap almost done, but not starting
The keys are not recognized by your new ecu and the immobilizer is doing its job lol. Is the green key light on?
Old Aug 9, 2012
Aetoc's Avatar
Aetoc will become famous soon enoughAetoc will become famous soon enough
Yea I'll have to second that one...the only other thing I can think of is the crank sensor isn't working...the car won't start if it doesn't know when cyl 1 is at tdc. My buddy had the same issue with his mazda p5...the woodruff key on his crank pully slipped out and the pully moved just enough to throw the timing out of whack. Either way, start with the immobilizer.
Old Aug 9, 2012
I concur with the immobilizer, rather, your key needing to be reprogrammed, being the culprit. You won't be able to go to the dealership and use your VIN to get it reprogrammed either.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
thana
Jun 15, 2020 07:05 PM
LionSpratt
Apr 26, 2015 01:02 PM
black2k1vtec
Dec 6, 2001 09:49 PM
supercivic01
South
Nov 30, 2001 11:27 AM
