2000 civic alignment (specs posted)
Old Aug 7, 2012
DareLG's Avatar
DareLG is an unknown quantity at this point
Exclamation 2000 civic alignment (specs posted)
Hello, I have a 2000 Honda Coupe EX. I jumped a curb and side swiped a curb. My rear left lower control arm was bent, and I replaced it. The rear left subfame is also semi-ripped where the screw hole for the LCA screws goes. I temporarily fixed it with jb-weld but am going to need to replace the entire left subframe. Currently, my vehicle pulls to the left. and when I drive straight my vehicle steering wheel is exactly positioned like this to keep the car driving straight.
Here is my alignment specs.
I am going to replace both front lower control arms, will this help with my alignment (caster)?
Thank you.
Old Aug 7, 2012
sl33pyriceboi's Avatar
Re: 2000 civic alignment (specs posted)
JB weld??? jeeeeeze and here i thought i used it for everything.
that dash doesnt look like a 2000 civic tho.
Old Aug 7, 2012
DareLG's Avatar
that steering wheel is not the actual picture of my civic. i just used it as reference.
Old Aug 7, 2012
DareLG's Avatar
yeah my transmission case also got cracked. i drained the transmission oil filled the crack with jb weld and good as new! no leaks what so ever.
Old Aug 7, 2012
DareLG's Avatar
ok just ordered two front lca with bushings and ball joints for 155 shipped. any instructions on how to install them? thanks.
Old Aug 8, 2012
DareLG's Avatar
this is how my driver side wheels looks like. wheel pushed towards rear.
Old Aug 8, 2012
^ is this with the new arms? ...
Old Aug 9, 2012
DareLG's Avatar
no, not new arms, old arms. hopefully the two lca will fix my steering problem and there will not be an issue with my front subframe.
Old Aug 9, 2012
hope all goes well
Old Aug 11, 2012
DareLG's Avatar
did not work
rcolosi
Apr 29, 2015 07:48 PM
shawe90
Apr 14, 2015 07:10 PM
tattedlariat
Apr 12, 2015 07:55 PM
dubbc
Nov 7, 2001 02:24 PM
silvervtec01
Nov 4, 2001 06:56 PM
