03 civic lx car won't start
Old Aug 7, 2012
rvelasco0819's Avatar
rvelasco0819 is an unknown quantity at this point
Hello
I have a 03 civic lx and my issue is that my car won't start. My headlights work fine but when I turn the key nothing else turns on or no clicking noise. *
I tired jumping no luck. I checked the voltage of the battery and is putting out 12.58 which is correct I think.*
The issue I think is I checked under the steering wheel and the 12 volt constant white wire does not provide any voltage which I think should always be reading 12 volts.*
At this point idk what to test or do or have a idea that the issue might be.*
Old Aug 7, 2012
GolNat's Avatar
Prelude Owner
Re: 03 civic lx car won't start
Yes, the white wire is your 12v constant for your ignition. You need to trace that wire to find out where your 12v is going. That 12v white wire provides the 12v for your accessories and your starter. Does the green immobilizer key come on?
Edit: check your fuses too.
Old Aug 7, 2012
palsana's Avatar
palsana is an unknown quantity at this point
check fuel pressure & fuel pump? i had car not start and i changed fuel pump and went very well. All charging systems were tested and were ok before fuel pump change.
Old Aug 7, 2012
I will try to track where the wire goes. And have to test the fuses. Any best way to test fuses?
Old Aug 7, 2012
GolNat's Avatar
Prelude Owner
To check a fuse you can tell by looking at it, but sometimes they look good and there not, so the best way is with a multimeter. Switch your multimeter to ohm's (%u03A9) and measure across the two terminals. It should read low resistance, less than 1 ohm is a good fuse.
Edit: check fuses #19 and #20 in under hood fuse box and starter cut relay in under dash fuse/relay box. Also fuse #13 in under dash box. This is for 01-02 civic. Check your manual to see if it matches.
Old Aug 8, 2012
It was fuse number 20 thank you all !!
Old Aug 8, 2012
Now I noticed my dashboard lights like A/C or heat ***** do not light up at night but the fuses are tested and good. Could that be a bulb itself?
Old Aug 8, 2012
GolNat's Avatar
Prelude Owner
If the fuses are good then yes it could be the bulbs, or a loose connection. Stuff can rattle loose overtime, especially if the radio was removed and replaced with an aftermarket one.
Old Aug 8, 2012
anibis's Avatar
anibis will become famous soon enoughanibis will become famous soon enough
Is this a new issue? Or have they been out for awhile?
There's 4 or 5 bulbs for the HVAC controls, usually a good idea to replace em all so you don't have to tear it apart again.
Old Aug 9, 2012
New issue. The lights that tell me a/c ,defrost and Recirculated air are on or off work but dimmers do not. I'll have to check the bulbs
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
Richkid23
Apr 19, 2015 12:53 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
