P0134 Code - Troubleshooting?
Old Jul 23, 2012
threeoten's Avatar
threeoten is an unknown quantity at this point
I had autozone pull a P0134 code after the engine light came on in my 03 Civic SI 2.0L which reads as follows:
A/F sensor 1 heater system malfunction
Probable cause:
1 - Open or short circuit condition
2 - Poor electrical connection
3 - Faulty A/F sensor
So, how do I go about testing for a short circuit or poor connection?
And if it IS a faulty sensor, is it the one in the upper exhaust pipe? or the one sticking out of the converter?
thanks
Old Jul 23, 2012
Re: P0134 Code - Troubleshooting?
Oh, I remember you now......Are you Canadian?
Sensor #1, upstream, or B1S1, is the first one in the exhaust. The one in front of the cat element, not in or behind the cat element.
P0134, A/F Sensor, No Activity Detected
99% just need a new sensor. It is not an Oxygen sensor, it is an Air-Fuel Ratio sensor.
Similar appearance, similar function, vastly different in construction and operation.
Use DENSO, NTK, or factory parts (Denso and NTK are both OEM).
Item #17 here (for US cars):
http://www.hondaautomotiveparts.com/...PIPE+-+MUFFLER
No. Bosch. Evar.
HTH
Old Jul 24, 2012
threeoten's Avatar
So is it worth checking out the existing sensor for a short circuit or anything first before throwing a new part at it?
Old Jul 24, 2012
Tough to say.
Look the wiring over real good, make sure it isn't rubbing on anything or rubbed through the insulation and exposed bare wires anywhere.
I watch data on the scanner. If the sensor shows activity at all, then the wiring is probably ok and the sensor itself is faulty.
Most of these sensors fail for this particular code intermittently, so catching it in the middle of a failure is tough.
I keep spares of many of the sensors in my toolbox, makes it easy to just plug one in and check.
I would probably just toss a sensor at it.
Old Jul 24, 2012
threeoten's Avatar
Yeah, the engine light comes on sometimes, but not every time. Sometimes it even pops on after driving for a while. It seems really intermittent.
Old Jul 24, 2012
threeoten's Avatar
So you'd put a new sensor in there even though it's seemingly intermittent?
Old Jul 25, 2012
threeoten's Avatar
Bought the new part anyways.. anyone know of a good tutorial?
Old Sep 2, 2012
Yes.
Not really. The hex is 7/8 inch, like any other O2 sensor.
Here are a couple examples of the special tools available, pick whatever fits your needs.
HTH
Old Nov 4, 2012
streetrod-smart's Avatar
streetrod-smart is an unknown quantity at this point
I Have a 2003 SI 2.0 L, I have replaced both sensors & the "mant. req." light is still on, the engine decoder says no activity detected, any ideas ?
Old Nov 4, 2012
Why on Earth would you just replace a pile of sensors without a good reason?
Oh wait, nevermind.
The maint req'd light is the oil change reminder.
Most places that do oil changes don't remember to reset it.
Reset instructions are in your owners manual.
SimpleUser
Apr 24, 2021 02:54 AM
Civic15
18
Sep 19, 2017 07:48 PM
Dangerousjordan
Jul 30, 2015 11:19 AM
Green02civic
Jul 27, 2015 10:48 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
